Docker Runtime issue on Jetson Orin Development kit
I am continuously getting the following error and unable to start Docker properly, even flashing all again via SDK Manager gives the same error. Please Help as System is down.
What ever way I tried, even skipping NVIDIA Container Runtime installation with SDK manage and doing it later, I did not get the Docker working. I tried Docker installation various ways, cleaning it and doing it does not get Docker issue fixed. Docker logs does not give me any sensible indications. During Ubuntu boot I do get this security warning, probably not linked to this Docker issue.
PEND]
Dependency failed for SSSD NSS Service responder socket.
PENDI
Dependency failed for SSSD AutoFS Service responder socket.
PEND]
Dependency failed for SSSD PAC Service responder socket.
PEND]
Dependency failed
for SSSD PAM Service responder private socket.
PEND]
Dependency failed
for SSSD PAM Service responder socket.
PENDI
Dependency failed for SSSD SSH Service responder socket.
PEND]
Dependency failed for SSsD Sudo Service responder
Some questions need to confirm
  • What is your host environment? Is it a Ubuntu OS?
  • What is your target JP version?
  • Is your device a Jetson Nano or Jetson Orin Nano?
Hello, I found the issue, It is due to latest Docker Release 28.0 which requires changes on Nvidia Kernel to work properly. I went back to Docker 27.5.1 and it worked well.
For reference, I am based on Jetson AGX ORIN 64GB development Kit and flashed with Latest OS with SDK Manager. Thanks to JIM from Jetson Hacks.
