I get warnings like this and the video window doesn’t open
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstNvOverlaySink-nvoverlaysink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow
It’s a warning, you can ignore this, the buffer is arriving late, not at expected time, that’s why you got the warning. about can not open the window, where did you run the sample? through remote login like putty or through desktop?
It works directly through monitor. I am not sure if I am using eglsink. I might be since when I try the same configuration on X2Go Client I get “No EGL display”.
It uses all of the 2GB memory and a low memory warning pops up. How can I reduce the number of input streams to possibly reduce memory footprint?
There is also an issue with the desktop mode with directly connecting to the monitor. Mouse is out of sync with desktop coordinates which makes it very hard to use.
in the source* group in config file, there num-sources property you can set, to lower number, you also can use config file samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt which have optimization for nano.
