Does DriveOS Support Flashing Different targetfs.img for A/B chain?
DRIVE OS Version: 6.0.10
Issue Description: Based on my current validation results, the A/B chain partition sizes can be different (for example, configuring the UFS partitions as 90 GB for chain A and 10 GB for chain B). The rootfs sizes can also differ accordingly (e.g., 87 GB for chain A and 8 GB for chain B).
However, the targetfs.img specified for both slots must be the same. When I configure different targetfs.img files for chain A and chain B, the images can be generated and flashed successfully, but the system fails to boot.
I would like to confirm whether this usage is fundamentally unsupported by DriveOS from a design or technical perspective. If it is supported, could you advise which areas I should investigate to debug and locate the root cause (for example, bootloader configuration, chain metadata, filesystem layout, or integrity checks)?
This forum is exclusively for developers who are part of the NVIDIA DRIVE® AGX SDK Developer Program | NVIDIA Developer . To post in the forum, please use an account associated with your corporate or university email address. This helps us ensure that the forum remains a platform for verified members of the developer program.
