• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version : DS6.0, DS6.1.1
• JetPack Version (valid for Jetson only) : 4.6(DS6.0), 5.0.2(DS6.1.1)
• TensorRT Version : 8.0.1(DS6.0), 8.4.1(DS6.1.1)
• Issue Type( questions, new requirements, bugs) : questions
When I ran this pipeline on Jetson(DS6.1.1) for about 12 hours , I was able to verify by using the ps command that it kept raising the physical memory usage without staying at a constant value.
When I removed nvinferaudio from this pipeline and ran it on Jetson(DS6.0) for about 12 hours, I could see that it kept the physical memory usage at a constant value.
I think that nvinferaudio is causing the physical memory usage to go up, is this a memory leak?
I run this command in the docker container.
command(with nvinferaudio)
/opt/nvidia/deepstream/deepstream/user_additional_install.sh
export USE_NEW_NVSTREAMMUX=yes
gst-launch-1.0 rtspsrc protocols=tcp location=rtsp://<IP Address>:554/test.mpeg4 latency=100 drop-on-latency=true name=source1 ! decodebin ! audioconvert ! audioresample ! "audio/x-raw,rate=44100" ! audio_mux.sink_1 \
nvstreammux batch-size=1 name=audio_mux ! queue ! nvinferaudio model-engine-file="/engine.engine" batch-size=2 audio-transform="melsdb,fft_length=2560,hop_size=692,dsp_window=hann,num_mels=128,sample_rate=44100,p2db_ref=(float)1.0,p2db_min_power=(float)0.0,p2db_top_db=(float)80.0" config-file-path=/opt/nvidia/deepstream/deepstream/sources/SONYCAudioClassifier/config_infer_audio_sonyc.txt audio-framesize=441000 audio-hopsize=110250 !tee ! fakesink enable-last-sample=false sync=false max-lateness=-1 async=false qos=false
command(without nvinferaudio)
nvstreammux batch-size=1 name=audio_mux ! queue ! tee ! fakesink enable-last-sample=false sync=false max-lateness=-1 async=false qos=false
I collected %MEM, VSZ and RSS data every 5 seconds using this command.
So the first column of the log displayed is %MEM, the second column is VSZ, and the third column is RSS.
ps -aux | grep -v "grep" | grep gst-launch-1.0 | awk '{ print $4,$5,$6 }'
log(with nvinferaudio)
11.9 35953968 3744772
11.7 36503036 3665132
11.8 37167068 3697632
11.9 37167068 3734012
11.9 37167068 3734072
11.9 37167068 3734208
11.9 37167068 3734252
11.9 37167068 3734260
11.9 37167068 3734460
11.9 37167068 3734912
11.9 37167068 3734916
11.9 37167068 3734920
11.9 37167068 3734932
11.9 37167068 3734936
11.9 37167068 3734952
11.9 37167068 3734976
11.9 37167068 3734996
11.9 37167068 3735000
11.9 37167068 3735004
11.9 37167068 3735008
11.9 37167068 3735012
11.9 37167068 3735016
11.9 37167068 3735020
11.9 37167068 3735036
11.9 37167068 3735044
11.9 37167068 3735048
11.9 37167068 3735060
11.9 37167068 3735072
11.9 37167068 3735080
11.9 37167068 3735088
11.9 37167068 3735092
11.9 37167068 3735948
11.9 37167068 3737152
11.9 37167068 3738568
11.9 37167068 3738584
11.9 37167068 3738624
11.9 37167068 3738628
11.9 37167068 3738652
11.9 37167068 3738688
11.9 37167068 3738720
11.9 37167068 3738756
11.9 37167068 3738788
11.9 37167068 3738824
11.9 37167068 3738856
11.9 37167068 3738888
11.9 37167068 3738924
11.9 37167068 3738960
11.9 37167068 3738992
11.9 37167068 3739028
11.9 37167068 3739060
11.9 37167068 3739096
11.9 37167068 3739128
11.9 37167068 3739164
11.9 37167068 3739196
11.9 37167068 3739232
11.9 37167068 3739264
11.9 37167068 3739300
11.9 37167068 3739332
11.9 37167068 3739368
11.9 37167068 3739400
11.9 37167068 3739660
11.9 37167068 3739696
11.9 37167068 3739728
11.9 37167068 3739756
11.9 37167068 3740020
11.9 37167068 3740284
log(without nvinferaudio)
0.3 17716752 56040
0.3 17716752 56040
0.3 17716752 56304
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56568
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
0.3 17716752 56692
