I am running Jetpack 4.3 on the AGX Xavier. I installed via the SDK manager and added all the software packages. I found on a forum that the built in version of OpenCV does not support Gstreamer in Jetpack 4.1. Is that still true for later Jetpack versions? Is there a way to check? I am considering following these instructions: Build OpenCV 3.4 on NVIDIA Jetson AGX Xavier Developer Kit - JetsonHacks but am unsure if it is necessary as it is for Jetpack 4.1.
We have gstreamer + OpenCV samples in source code package:
https://developer.nvidia.com/embedded/dlc/r32-3-1_Release_v1.0/Sources/T186/public_sources.tbz2
Please download it and try.
Do there have gstreamer + OpenCV samples in C?
Searching this forum, you may find many examples for different use cases on various releases.
Hi @chemistry0421
You should also see C samples in source code package:
https://developer.nvidia.com/embedded/l4t/r32_release_v5.1/r32_release_v5.1/sources/t186/public_sources.tbz2
If you use v4l2src plugin, may refer to this sample:
Sony camera module cannot be opened with OpenCV on Xavier - #5 by DaneLLL
(Re-installing OpenCV is not required for later r32 releases)
