On the Orin platform, there are two ways to update the bootloader: Method 1: Install the CAP file, set the UEFI variables, and the bootloader will be updated after the UEFI restarts. Method 2: In compatibility mode, expose the MTD device and use the nv_update_engine payload method.
On Thor, Method 1 is the default option. Does it still support Method 2, i.e., updating via nv_update_engine?
4. Update the QSPI flash.
a. Copy the generated QSPI flash payload to the target filesystem.
$ scp ${Your_host_user_name}@${Your_host_IP}:${Your_path}/Linux_for_Tegra/Tegra_IGX_BL.Cap /opt
b. Execute the bootloader_updater utility to update the IGX bootloader on QSPI flash.
$ sudo nv_bootloader_capsule_updater.sh -q /opt/Tegra_IGX_BL.Cap
c. Reboot the tareget to update the QSPI flash image on non-current slot bootloader.
d. To check the Capsule update status, run the nvbootctrl command after boot to system:
$ sudo nvbootctrl dump-slots-info
Note: Capsule update status value "1" means update successfully. About the Capsule update status,
please refer to developer guide for more information.
e. To sync bootloader A/B slots, do the step b to d again.
f. Then the bootloader partitions on QSPI flash(both A/B slots) are updated.
OTA updates are completed in UEFI after a reboot. However, we want to complete this process in the system (during normal runtime), similar to the method used on Orin, via nv_update_engine
Thor (t264 series) has different boot logic with Orin (t234 series).
there’re lots of changes, please expect next Jetpack public release (i.e. JP-7.1) will support that.
Jerry:
Are there any plans for future releases (e.g., JP-7.1) to support OTA updates of the bootloader during system runtime, similar to how the nv_update_engine works on Orin?
FYI, updating the bootloader is executed in UEFI.
for Image-based OTA to update rootfs and also bootloader, updating rootfs is before updating the bootloader, once updating rootfs is finished, the device reboots, and then UEFI updates the bootloader through UEFI capsule update.
