1.Does Thor support fTPM?
2.can fTPM over OPTEE without fused can be used (on Thor)?
Related info:
in the THOR fuse doc.
FUSE_BOOT_SECURITY_INFO Boot Security Info
Bits interpreted by boot software with
following mapping:
Bit [3]: Secure boot encryption enable
Bit [5]: Revocation policy enable
Bit [9]: OEM Fuse Key Load
Bit [10]: Disable skip OEM authentication
for diagnostic boot
Bit [13]: OEM fTPM Feature enable
Bits not listed are reserved
=> bit13 available for fTPM feature on THOR
in Jetson Linux Developer guide / Security / Firmware TPM
“Applies to the Jetson AGX Orin series, Jetson Orin NX series, and Jetson Orin Nano series.”
=> no THOR is mentioned.
