azein90
January 11, 2022, 10:20am
#1
Hello Guys,
I can see that Xavier SoC has 8 Carmel Armv8 cores, but I am not sure if they are all APU or RPU?
I am wondering if such SoC can be used in automotive applications which needs a realtime core for Safety compliance.
Any information, white papers, or links would be really appreciated.
The visible cores are all Cortex-A series, which are far from realtime. You won’t be able to see it (normally), but the Audio Processing Engine (APE) and Sensor Processing Engine (SPE) are Cortex-R series (Cortex-R5). The Cortex-R5 is rather low power.
There are cases where the Cortex-M can be used for hard realtime, but it is limited. For a case as critical as something like an autonomous vehicle you would need a separate Cortex-R series board which is communicating with the Jetson. Do keep in mind though that actual automobile hardware is a different product line. See the “Drive” series for something more suitable for vehicles:
https://forums.developer.nvidia.com/c/agx-autonomous-machines/drive-px2/61
https://forums.developer.nvidia.com/c/agx-autonomous-machines/drive-agx/57
The Cortex-R5 Sensor Processing Engine (SPE) that @linuxdev mentioned is programmable and you can find resources for it here:
https://developer.nvidia.com/embedded/downloads#?search=Jetson%20Sensor%20Processing
azein90
January 12, 2022, 12:21pm
#4
I was looking for more information about Xavier SoC itself not Jetson as I found it is qualified for automotive applications already: https://www.tuvsud.com/en/e-ssentials-newsletter/rail-essentials/e-ssentials-2-2018/safety-concept-assessment-for-nvidia-xavier-system-on-chip-to-foster-safe-autonomous-driving
The problem is that I cannot find much material about the SoC detailed specifications.
@dusty_nv That looks interesting, do you know if there is any doc that illustrate the detailed specification for Xavier SoC?
Hi @azein90 , I would refer you to the module datasheet and the SoC technical reference manual:
azein90
January 13, 2022, 11:39am
#6
That’s exactly what I was looking for, Thanks a lot @dusty_nv !
system
closed
January 27, 2022, 11:40am
#7
