Hello everyone,
I am using an IMX678 on a Jetson AGX and I am experiencing issues with the DOL2-HDR mode. The image combination is correct when there is no movement. However, when an object moves from a dark area, where the long exposure frame is dominant, to a bright area, where the short exposure frame is dominant, an artifact appears. Specifically, the “overexposed” area appears pink in this situation. This phenomenon suggests that the image combination calculation was done on the previous frame.
In the attached images, you can see that when I pass my arm in front of the window, the shape of the window can be discerned with a lot of noise. However, in the next frame, the pink shape disappears.
I would like to know if there is a way to correct this issue.
Have a good day,
Best regards,
