IMX577 DOL HDR Corrupted Result
Hello everyone,
I have posted many posts about DOL HDR feature, sorry about that. However, I made progress about DOL HDR.
Here is my device tree for DOL HDR mode.
mode1 {
						mclk_khz = "24000";
						num_lanes = "4";
						phy_mode = "DPHY";
						discontinuous_clk = "yes";
						dpcm_enable = "false";
						cil_settletime = "0";
						dynamic_pixel_bit_depth = "10";
						csi_pixel_bit_depth = "10";
						mode_type = "bayer_wdr_dol";
						pixel_phase = "rggb";
						active_w = "3856";
						active_h = "4448";
						readout_orientation = "0";
						line_length = "4208";
						inherent_gain = "1";
						mclk_multiplier = "24";
						pix_clk_hz = "576000000";
						gain_factor = "1000000";
						min_gain_val = "1000000";
						max_gain_val = "30000000";
						step_gain_val = "1";
						default_gain = "1000000";
						min_hdr_ratio = "32";
						max_hdr_ratio = "32";
						framerate_factor = "1000000";
						min_framerate = "1500000";
						max_framerate = "30000000";
						step_framerate = "1";
						default_framerate = "30000000";
						exposure_factor = "1000000";
						min_exp_time = "864";
						max_exp_time = "20480";
						step_exp_time = "1";
						default_exp_time = "20480";
						embedded_metadata_height = [32 00];
						num_of_exposure = "2";
						num_of_ignored_lines = "14";
						num_of_lines_offset_0 = "50";
						num_of_ignored_pixels = "4";
						num_of_left_margin_pixels = "12";
						num_of_right_margin_pixels = "0";
Also I added these lines to camera_overrides.isp.
wdr.DOL.v4.EnableDOL = TRUE;
ae.wdr.DreMin = 16;
ae.wdr.DreMax = 16;
However, I get this corrupted image when I execute nvgstcapture-1.0.
nvgstcapture-1.0 gives healthy results for other resolutions.
What should I do now?
Thank you.
The ae.wdr.DreMin/DreMax should be the same with max/min_hdr_ratio
I did. Still the same corruption is. Could you see any other correction?
@ahmetksasmaz
I would suggest to contact with camera partner for this advance feature.
