Hello Guys I have doubt regarding SDK manager installation like I am planning to downgrade from jetpack 6.1 to jetpack 5.
In the step2 part I have a doubt regarding the Download folder and target folder because I have inserted the SDcard in the jetson orin nano itself and Connecting it so for the download folder and target folder what should I select.
It does not matter. Those path are not related to your sdcard.
It is just where the flash tool will be put into your host PC. The flash tool will flash your sdcard though usb cable between Jetson and your host.
Hello @WayneWWW Can you please help me with this
I have attached the logs in the above
The 3 logs you shared are all different cases
first log indicates your board is not in recovery mode
second log indicates a weird error which needs something else to check further.
The 3rd log which is your screenshot does not have any error but seems just in the middle of flash. What is the result in the end from your 3rd log?
Hello @WayneWWW, there is no third log I just take screenshot of it while performing the 2nd log
Is your host machine a VM? or it is native ubuntu host?
Please use a native ubuntu host as VM has unstable usb link connection.
Hello @WayneWWW I have tried with native ubuntu host but still it is not working like the device is already in recovery mode only. but still it doesn’t work
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Orin_Nano_8GB_2024-11-13_15-23-06.zip (411.0 KB)
Hello @WayneWWW the device is already in recovery mode only.
ravikumar:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 014: ID 0955:7523 NVIDIA Corp. APX
Bus 001 Device 003: ID 413c:2113 Dell Computer Corp. Dell KB216 Wired Keyboard
Bus 001 Device 002: ID 413c:301a Dell Computer Corp. Dell MS116 USB Optical Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
can you please help me with this I have attached the logs in the above response
Are you sure your type C cable is okay? How about changing it to other kind?
Hello @WayneWWW I have tried with different cable as well but it is also not working with that.
Please use Manual Setup if your board has been in force recovery state already.
Have you confirmed that you are connecting only one Jetson device?
15:23:15.202 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: *** Reading ECID ... SDKM_INSTALL_ERROR *** Error: ECID read failed.
15:23:15.202 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: *** Reading ECID ... SDKM_INSTALL_ERROR *** Error: ECID read failed.
15:23:15.203 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Put the target board in RCM mode and retry.
15:23:15.203 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: Put the target board in RCM mode and retry.
15:23:15.203 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: *** ERROR: Parsing boardid failed
Have you confirmed that you are using the Orin Nano devkit?
Hello @KevinFFF, I have been using the jetson orin nano devkit only and I am connecting only one device.
I have tried both Manual and Automatic setup in the SDK Manager.
Is there any other way to downgrade from jetpack 6 to jetpack 5
Hello @KevinFFF and @WayneWWW Is there any other way to downgrade it from jetpack6 to jetpack5 other than SDK manager if it is there please give me step by step instructions to do that.
Hello @KevinFFF I have tried with this method
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/IN/QuickStart.html#to-determine-whether-the-developer-kit-is-in-force-recovery-mode
downloaded these things
and tried to downgrade it but it is not downgrading I am attaching the logs for further reference.
logs.txt (195.8 KB)
Hello @KevinFFF and @WayneWWW can anyone of you help me to solve this issue please.
Try this method to dump the serial console log from the device side during flash failure.
