I had previously went to the following hyperlink, downloaded the “JETSON ORIN NANO DEVELOPER KIT”. Once I extracted the zip file, I used BalenaEtcher to make the bootable microSD card using the provided image file ‘sd-blob.img’.
Hello Dave,
I installed the SDK manager on my Ubuntu laptop, and have the jetson connected to my pc via a USB C to USB A cable.
However, SDK manager is still not able to detect my device.
Furthermore, the box my NVIDIA ORIN NANO came in just says that, it does not specify NX.
How do I know what model mine is? According to the underside of the box my Jetson the model number is P3766 which according to Google is the NX model, but wanted to confirm that it in fact is the NX model opposed to a different variant of the Nano Orin.
The other specs on the box list that this device has 8GB 128 bit LPDDR5 with 6-Core arm Cortex A78AE v8.2
Thank you by the way for all of your assistance thus far
Also note, my laptop does not have a USB C female port, just USB type A. The cable is able to be used with connection to my Samsung phone for USB debugging. I am assuming it can also connect to the Jetson.
If not, can you provide alternate ways to communicate with this Jetson device?
I was able to provide the Jetson Nano an IPv4 address via system setup using the esc key and am able to ping its IPv4 address since both my laptop and jetson are connected via a l2 switch.
