After I Install QSPI Updater Debian package, I rebooted and powered off the dev kit as instruction. But I plugged it on again and it automatically shut down during booting. The fan also
stopped.
and serial port console show that:
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: ERROR: Invalid header detected on UEFI supplied FDT, ignoring ...
EFI stub: Generating empty DTB
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
Please connect the USB-C port of your Jetson Orin Nano devkit to your host PC.
I’m not clear about where you get stuck and fan not working to cause it hot.
Please just use the SDK Manager to flash the board to check if it could work and share the full flash log for further check.
I try again, but installation failed. And terminal show that.
22:00:19 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:21 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:22 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:25 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:29 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:40 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
22:00:50 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 41m11s ]
22:00:50 ERROR: Flash Jetson Linux - flash: command terminated with error
22:00:50 SUMMARY: DateTime Target Setup - target: Depends on failed component
my jetson can’t boot, and can’t connect internet. How should I do?
SDK Manager is verifying Jetson Orin Nano modules system readiness to install.
Disk space.
Internet connection.
Access to APT repository and ability to install Debian packages with it.
SDK Manager detected your system may not ready for installation, see specific errors below.
Once fixed, click 'Retry' to verify system readiness again.
'Skip' this process may result install installation failure.
Internet connection.: Internet connection check failure.
command < ssh -F /dev/null -o PreferredAuthentications=password -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 qxy@192.168.55.1 'ping -c 3 nvidia.com || wget --spider -T 5 -t 1 www.nvidia.com' > terminated with error, exitCode: 4.
Access to APT repository and ability to install Debian packages with it.: Apt repository check failure (1. sudo apt-get update && sudo apt-get check; 2. sudo dpkg --audit).
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/jammy/InRelease is not valid yet (invalid for another 19103d 16h 45min 2s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/jammy-updates/InRelease is not valid yet (invalid for another 19926d 5h 27min 31s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/jammy-backports/InRelease is not valid yet (invalid for another 19923d 20h 18min 25s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/jammy-security/InRelease is not valid yet (invalid for another 19926d 5h 49min 22s). Updates for this repository will not be applied.
PC finally displayed installation failed, but jetson can boot and use linux instructions. How do I check if I reflash successfully. What should be done in the future before development.
qxy@qxyComputer:~/Desktop$ uname -a
Linux qxyComputer 6.5.0-44-generic #44~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Jun 18 14:36:16 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
I have no another one.
my jetson will leave recovery state in the process of using the SDK. logs.txt (1.7 MB)
23:11:11.394 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.ipksnFjL8X. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
23:11:11.395 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:
23:11:12.256 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Cleaning up...
