Iβm trying to start my Jetson Orin Nano dev kit according to that guide: π Initial Setup Guide - Jeton Orin Nano π - NVIDIA Jetson AI Lab. As my firmware seems to be older than 36.3, I flashed sd card with JetPack 5.1.3 to update firmware. When Iβm powering up module with jetpak 5.1.3, Instead of installing system as in step 3 of tutorial, it just opens the terminal after the boot screen. Terminal looks to be useless, nothing can be done here. How to boot my module?
Previouselly I just been flashing SD card. According to your commentary I started to play around SDKmanager. Spent few hour for it but still without success.
I installed SDKmanager with docker, as my linuxmint seems to not support normal version. Using docker I see the only possibility to run sdkmanager in cli version (or there is some possibility to run it with gui?). When Iβm trying to flash connected device through usb, it seems there is lack of connection with device (probably there is some connection procedure). How can I connect device with PC then?
