Are we being forced to use 580? I’m finding that, say, Horizon Zero Dawn freezes from time-to-time in a way that it didn’t before on 550.
I should add that I’m using an RTX2060 laptop model NVIDIA (still - I can’t wait ‘til I can afford a new system and get away from the NVIDIA driver mess).
To reproduce the freeze is relatively simple. I run Horizon Zero Dawn (remastered) via Wine 10.16 with:
vkd3d-proton 2.14.1
dxvk 2.6.2
dxvk-nvapi 0.9
Running in a virtual desktop, simply switch between windows and eventually it will freeze. Things like v-sync, dlss, etc, don’t seem to make a difference. It seems to be an issue with the newer driver; I would 100% confirm this, but as I mentioned - it’s not possible to downgrade via the PPA anymore.
This happens with most games that are using D3D whenever they are windowed or on a virtual desktop.
This wasn’t happening before on 550; but now that I’ve been bumped off of 550, I’m finding that both 570 and 580 freeze whenever I Alt+Tab out of Wine.
I’m running into the same issue. I can confirm every driver release after 550.144.03 causes crashes/freezes on Ubuntu 24.04, with X11 on my RTX2060 laptop.
I put my workaround to rollback and stay at driver version 550 here: 580 release feedback & discussion - #644 by m.mucahidbenlioglu I’m copy pasting it here as well for reference
As a workaround I uninstalled nvidia-driver-550, nvidia-driver-580 and all related packages, removed noble-updates in /etc/apt/sources.list.d/ubuntu.sources, reinstalled nvidia-driver-550 which installs 550.144.03-0ubuntu0.24.04.1 and then froze the following packages with apt-mark so that they aren’t updated until a fixed driver version is released, and re-enabled noble-updates repository
Thanks, was a little trickier for me. I had to roll back to the 6.11 kernel first and remove the HWE kernel for24.04 (which is 6.14) because 550.144.03 as packaged does not compile on 6.14.
The command I used once I had the right kernel was:
I appear to have the same issue with a NVIDIA GeForce RTX 3050 Laptop GPU: ever since being forced to update from 550 to 580, games that ran fine on Proton Hotfix earlier now freeze seemingly at random, and also more predictably when alt-tabbing back and forth from another window. The freezing doesn’t effect audio or a console logging game events in the background, only graphics. I tried aggressively alt-tabbing 4 different games running in Proton and all of them eventually froze, but some games are more prone than others, especially with the random freezing aspect.
Running Ubuntu 24.04.3, driver version is nvidia-driver-580-open (proprietry, tested) provided by Ubuntu’s “additional drivers”.
I couldn’t get an x server to start without immediately closing to run the bug report script but I wanted to note my experiences anyway to help confirm its effecting multiple users.
Looks like kernel 6.17 has truly deprecated the EXTRA_CFLAGS and hence the Ubuntu 24.04 package for building the module is now broken if using the HWE kernel.
I can see exactly what needs to be updated in the Kbuild file, but I haven’t done enough packaging to have a clean solution. Here’s the difference between the newer Kbuild scripts (570) and the Kbuild script in 550.163.01 (which I’m currently stuck on due to these freezes):
Turns out, there has also been a change to the interface of drm_helper_mode_fill_fb_struct and possibly some others. I’ll see if I can backport the smallest set of changes from 580 to patch this, too.
God i hate how this issue is still somehow present.
Nvidia driver 590-open seems to partially resolve the issue but its so brittle that it doesn’t solve it at all, the game will run fine but the moment there is hiccups or slight freezes from the system it immediately drops the game and it freezes indefinitely. Something like turning up the volume will cause the OSD to appear on screen and glitch out the game, causing it to freeze.
This is on Linux Mint Cinnamon 6.6.7 X11 with dual monitors (my laptop and an external monitor) This is also on a GTX 1650 TI Mobile.
