Hi NV people
i use dp monitor and hdmi monitor to connect my nano.
but it can’t work on dual monitor.
in the boot time i can see the boot message on hdmi monitor.
after boot up i can see the GUI only on DP monitor.
Hi NV people
Hi etta,
Can display work if you plug them separately?
case1. only HDMI
case2. only DP
case3. connect HDMI first/ then DP and vice versa. (after boot up)
case4. both connected before boot up.
Hi WayneWWW
case1. it can work
case2. it can work
case3. after connect DP monitor, the hdmi will no signal output. the GUI will change to DP port.
case4. login gui will show on hdmi monitor , but after login the hdmi will no signal output
Did DP and HDMI can work work on same time?
You could try to share the kernel log of case 3.
But it does not sound like a software issue since single monitor case can work. Could you share the spec of your power adapter?
Hi etta,
Hi kayccc
after i rebuild the kernel it can support DP and hdmi.
