I want to print out the screen with the DP port at the beginning of JETSON NANO. If you connect the HDMI, the screen is output, but if you connect only the DP port, the screen is not output. What is the reason?
Please provide more information what does that mean.
Have you device been flashed with newer SW? which JetPack?
You mean you plugged a DP monitor but there is no output?
