Guys, I seem to encounter a memory leak problem when using DOCA DPA lib.
Here is my code:
class DpaKernel {
DpaKernel() {
doca_dpa_create(dev->get_dev(), app, &dpa_ctx, flags);
~DpaKernel(){
if (dpa_ctx != nullptr)
result= doca_dpa_destroy(dpa_ctx);
And when I call the dealloc function of my class, the program fail to release flexio heap, the command line shows these error:
heap_destroy 317 - Failed to destroy heap, not all device heap memory was freed
flexio_process_destroy 907 - Failed to release prm heap memory
flexio_process_destroy 914 - Failed to destroy process PRM object (err = 22)
And LeakSanitizer detects the following memory leak stack info:
==1513557==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 48 byte(s) in 1 object(s) allocated from:
#0 0x7fb37227ea57 in __interceptor_calloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cpp:154
#1 0x7fb3720eab02 (/lib/x86_64-linux-gnu/libmlx5.so.1+0x68b02)
#2 0x7fb3721b39fe in flexio_create_prm_process ../libflexio/src/flexio_prm.c:252
#3 0x7fb3721ac1c3 in process_create ../libflexio/src/flexio.c:689
#4 0x7fb3721ac1c3 in flexio_process_create ../libflexio/src/flexio.c:845
#5 0x7fb37218377e (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0x877e)
#6 0x7fb37218621d in doca_dpa_create (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0xb21d)
#7 0x40fdab in dpu::DpaKernel::DpaKernel(std::shared_ptr<dpu::DpaDevice>&, doca_dpa_app*, unsigned int) /home/chengrx/dpa_bench/src/dpa/dpa_kernel.cc:12
#8 0x421ed2 in test::DpaKernel_Launch_Test::TestBody() /home/chengrx/dpa_bench/test/dpa/test_dpa_kernel.cc:12
#9 0x4c5397 in void testing::internal::HandleSehExceptionsInMethodIfSupported<testing::Test, void>(testing::Test*, void (testing::Test::*)(), char const*) /home/chengrx/dpa_bench/deps/googletest/googletest/src/gtest.cc:2612
#10 0x4b2e17 in void testing::internal::HandleExceptionsInMethodIfSupported<testing::Test, void>(testing::Test*, void (testing::Test::*)(), char const*) /home/chengrx/dpa_bench/deps/googletest/googletest/src/gtest.cc:2648
#11 0x459c25 in testing::Test::Run() /home/chengrx/dpa_bench/deps/googletest/googletest/src/gtest.cc:2687
Direct leak of 40 byte(s) in 1 object(s) allocated from:
#1 0x7fb3721a9c96 in heap_block_create ../libflexio/src/flexio_heap.c:55
#2 0x7fb3721a9c96 in heap_malloc ../libflexio/src/flexio_heap.c:249
#3 0x7fb3721b5dcf in flexio_buf_dev_alloc ../libflexio/src/flexio_mem.c:134
#4 0x7fb3721b5dcf in flexio_buf_dev_alloc ../libflexio/src/flexio_mem.c:116
#5 0x7fb3721b1e42 in internal_msg_stream_create ../libflexio/src/flexio_msg_stream.c:486
#6 0x7fb3721b2c1d in flexio_msg_stream_create ../libflexio/src/flexio_msg_stream.c:797
#7 0x7fb3721837e3 (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0x87e3)
#8 0x7fb37218621d in doca_dpa_create (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0xb21d)
#9 0x40fdab in dpu::DpaKernel::DpaKernel(std::shared_ptr<dpu::DpaDevice>&, doca_dpa_app*, unsigned int) /home/chengrx/dpa_bench/src/dpa/dpa_kernel.cc:12
#10 0x421ed2 in test::DpaKernel_Launch_Test::TestBody() /home/chengrx/dpa_bench/test/dpa/test_dpa_kernel.cc:12
#11 0x4c5397 in void testing::internal::HandleSehExceptionsInMethodIfSupported<testing::Test, void>(testing::Test*, void (testing::Test::*)(), char const*) /home/chengrx/dpa_bench/deps/googletest/googletest/src/gtest.cc:2612
#12 0x4b2e17 in void testing::internal::HandleExceptionsInMethodIfSupported<testing::Test, void>(testing::Test*, void (testing::Test::*)(), char const*) /home/chengrx/dpa_bench/deps/googletest/googletest/src/gtest.cc:2648
Direct leak of 32 byte(s) in 1 object(s) allocated from:
#1 0x7fb3721a99d1 in heap_malloc_from_pool ../libflexio/src/flexio_heap.c:185
#2 0x7fb3721a9e0b in heap_malloc ../libflexio/src/flexio_heap.c:264
Indirect leak of 48 byte(s) in 1 object(s) allocated from:
#2 0x7fb3721b3748 in flexio_create_prm_heap_mem ../libflexio/src/flexio_prm.c:179
#3 0x7fb3721a9d5f in heap_block_create ../libflexio/src/flexio_heap.c:67
#4 0x7fb3721a9d5f in heap_malloc ../libflexio/src/flexio_heap.c:249
#5 0x7fb3721b5dcf in flexio_buf_dev_alloc ../libflexio/src/flexio_mem.c:134
#6 0x7fb3721b5dcf in flexio_buf_dev_alloc ../libflexio/src/flexio_mem.c:116
#7 0x7fb3721b1e42 in internal_msg_stream_create ../libflexio/src/flexio_msg_stream.c:486
#8 0x7fb3721b2c1d in flexio_msg_stream_create ../libflexio/src/flexio_msg_stream.c:797
#9 0x7fb3721837e3 (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0x87e3)
#10 0x7fb37218621d in doca_dpa_create (/opt/mellanox/doca/lib/x86_64-linux-gnu/libdoca_dpa.so.2+0xb21d)
#11 0x40fdab in dpu::DpaKernel::DpaKernel(std::shared_ptr<dpu::DpaDevice>&, doca_dpa_app*, unsigned int) /home/chengrx/dpa_bench/src/dpa/dpa_kernel.cc:12
#12 0x421ed2 in test::DpaKernel_Launch_Test::TestBody() /home/chengrx/dpa_bench/test/dpa/test_dpa_kernel.cc:12
It seems that, the bug is related to how doca_dpa_create
and doca_dpa_destroy
are implemented, and I have no way to see the codes. May I ask how to fix the memory leak bugs?
