hi, nvidia:
I Installed driver by sudo ubuntu-drivers --gpgpu install
my video card:
lspci -k | grep -EA3 'VGA|3D|Display':
2d:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070] (rev a1)
Subsystem: LeadTek Research Inc. GA104 [GeForce RTX 3070]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
2d:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
sudo lshw -C display:
*-display
description: VGA compatible controller
product: GA104 [GeForce RTX 3070]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:2d:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list fb
configuration: depth=32 latency=0 resolution=1920,1080
resources: iomemory:38ff0-38fef iomemory:38ff0-38fef memory:b9000000-b9ffffff memory:38ffe0000000-38ffefffffff memory:38fff0000000-38fff1ffffff ioport:8000(size=128) memory:ba080000-ba0fffff
but I got:
nvidia-smi:
NVIDIA-SMI has failed because it couldnāt communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
nvitop:
NVML ERROR: Driver Not Loaded
for troubleshooting, what I have done:
lsmod | grep nvidia ā blank output
lsb_release -a :
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.1 LTS
Release: 24.04
Codename: noble
sudo dmesg | grep -i nvidia:
[ 7.369542] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:2c/0000:2c:00.0/0000:2d:00.1/sound/card1/input9
[ 7.369914] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:2c/0000:2c:00.0/0000:2d:00.1/sound/card1/input10
[ 7.370132] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:2c/0000:2c:00.0/0000:2d:00.1/sound/card1/input11
[ 7.370345] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:2c/0000:2c:00.0/0000:2d:00.1/sound/card1/input12
cat /proc/driver/nvidia/version
cat: /proc/driver/nvidia/version: No such file or directory
dkms status
nvidia/570.86.15, 6.8.0-52-generic, x86_64: installed
rmmod nvidia
rmmod: ERROR: Module nvidia is not currently loaded
sudo modprobe nvidia
modprobe: ERROR: could not insert ānvidiaā: Key was rejected by service
this is my log: nvidia-bug-report.log.gz or
nvidia-bug-report.log.gz (212.6 KB)
after reinstalled driver serveral times, problem still there
I had my HP Z8G4 secure boot down, help pls
