I am under Ubuntu 15.10 and i have installed nvidia drive (NVIDIA binary driver - version 364.15)
When i switch to nvidia driver the screen resolution is limited to 800*600 and the GLX extensions do not want to load
I’have this message on module loading :
dmesg | grep nvidia
[ 0.994500] nvidia: module license ‘NVIDIA’ taints kernel.
[ 1.004418] nvidia-nvlink: Nvlink Core is being initialized, major device number 247
[ 1.006202] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 364.15 Sat Apr 2 20:53:38 PDT 2016
[ 1.046210] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.350217] nvidia-modeset: Allocated GPU:0 (GPU-e8c8045f-badd-e1ea-c6f1-38df69de6f0a) @ PCI:0000:01:00.0
[ 2.350396] nvidia-modeset: Freed GPU:0 (GPU-e8c8045f-badd-e1ea-c6f1-38df69de6f0a) @ PCI:0000:01:00.0
[ 5.456025] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 13.080435] tpm_crb(+) parport_pc ppdev lp parport hid_logitech_hidpp hid_logitech_dj usbhid nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) i915(OE) i2c_algo_bit drm_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt fb_sys_fops libahci drm(OE) i2c_hid hid pinctrl_sunrisepoint video pinctrl_intel fjes
[ 23.734409] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 45.875560] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 45.875816] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 45.875959] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 48.207537] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 49.365322] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
[ 49.365406] [drm:nvidia_drm_master_drop [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] nvidia_drm_shut_down_all_crtcs() failed with error code -22.
When i switch to the Intel driver everything is ok.
I dont know what i am suppose to fix to resolve my problem.
Sincerely stefan.
ps:i am not a good english writer
