Driver randomly stopped gripping my gpu, and screen taring issue if i am able to fix this?
my setup has been working fine for a few days using the nvidia card according to nvidia-smi and settings, but today weven after some reboots, not blacklisted, modesetting is enabled, but rgw nvidia driver suddenly will not claim my gpu. i have a lot of flatpak apps that use this driver, so i can’t just reoinstall my distros version. i tried to delete all the old drivers and reinstall the .run file, the modprobe,d/nvidia.conf file didnt even exthist. made that it did nothing. when i run
"lspci -v it tells me that nvidia, nvidia-drm, and nvidia-fb are options, but none are used. one boot it just suddenly stopped working. given the lspci command works i know my gpu isnt bad. the gpu is seen as llvm 256 bit bt the gpu viewer program and clicking it nearly freezes my pc every time. what do i do here?
also what does "concider enabling stream paranoi=0 mean? did that disable prime on demand? before i lost my gpu to wjhatever this is, i’d get this error all the time. is the intel card lagging my system or? i usually run browser with many tabs in igpu and game on nvidia before this happened, screen taring was more with that stream paranoid=0 but it was less white screening when i closed gpu heavy apps
nvidia-bug-report.log.gz (91.4 KB)
