Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
[√] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[√] other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
When i use “recorder-tui” to record data, it can’t work, the error is “ModuleNotFoundError: No module named ‘Crypto’”, then i use “pip3 install Crypto” to install Crypto, it also has the error. But i use “recorder” with same rig file, it’s ok. The logs are as following:
nvidia@tegra-ubuntu:/usr/local/driveworks/tools/capture$ ./recorder-tui ./configs/release.json
./recorder-tui:1296: SyntaxWarning: “is” with a literal. Did you mean “==”?
if hostname is “local”:
./recorder-tui:1310: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
if hostname is not “local”:
running recorder-tui with arguments: Namespace(aes_key=None, aes_key_encrypted=None, backend=False, bbr=False, description=‘’, disable_encryption=True, enable_encryption=False, lane_id=None, log_dir_path=‘/tmp’, login_id=None, no_mount_check=False, no_sudo=False, non_interaction=False, remote_dw_path=‘’, rig=‘./configs/release.json’, route=None, rsa_key=‘/home/nvidia/.ssh/recorder-aiinfra.pem’, rsa_key_md5=None, skip_init_input=False, tag=‘NONE’)
File “./recorder-tui”, line 178, in
import recorder_utils as utils
File “/usr/local/driveworks-5.8/tools/capture/scripts/recorder_utils.py”, line 42, in
from Crypto.Cipher import AES
The rig file is as following:
“rig”: {
“properties”: {
“layout”: “Hyperion 7.1”
“sensors”: [
“name”: “camera:sample0”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [
0.0,
0.0,
0.0
“t”: [
1.8621,
-0.1939,
1.3165
“parameter”: “camera-name=F008A120RM0A,interface=csi-e,CPHY-mode=1,link=3,format=h264,output-format=processed,async-record=1,file-buffer-size=16777216”,
“properties”: {
“Model”: “ftheta”,
“bw-poly”: “0.000000000000000 5.35356812179089e-4 4.99266072928606e-10 4.27370422037554e-12 -6.68245573791717e-16”,
“cx”: “1927.764404”,
“cy”: “1096.686646”,
“height”: “2168”,
“width”: “3848”
“protocol”: “camera.gmsl”
“name”: “camera:sample1”,
“roll-pitch-yaw”: [
0.0,
0.0,
0.0
“t”: [
1.8621,
-0.1939,
1.3165
“parameter”: “camera-name=F008A120RM0A,interface=csi-e,CPHY-mode=1,link=1,format=h264,output-format=processed,async-record=1,file-buffer-size=16777216”,
“properties”: {
“Model”: “ftheta”,
“height”: “2168”,
“width”: “3848”
“vehicle”: {
“valid”: true,
“value”: {
“COMMENT”: “[date: 2020-01-19] mass and centerOfMass are measured with two persons in the front seats. vehicle yaw inertia (the 3rd element of inertia), front cornering stiffness, rear cornering stiffness and steering map are estimated with vehicle test data. roll and pitch inertia (inertia’s first and second elements) and height of center of mass are estimates. [date: 2021-07-21] throttleTorqueOutput resampled for throttleSpeedInput with values close to 0mps”,
“actuation”: {
“brakeActuatorTimeConstant”: 0.05,
“brakeActuatorTimeDelay”: 0.0,
“driveByWireTimeConstant”: 0.25999999046325684,
“driveByWireTimeDelay”: 0.10999999940395355,
“effectiveMass”: 389.8653869628906,
“maxSteeringWheelAngle”: 8.290313720703125,
“steeringWheelToSteeringMap”: [
0.0,
0.06459085643291473,
-2.557147672632709e-05,
1.8859604097087868e-05,
1.3523515463020885e-07,
4.7676653025519045e-07
“throttleActuatorTimeConstant”: 0.3,
“throttleActuatorTimeDelay”: 0.0,
“torqueLUT”: {
“brakePedalInput”: “0.15, 0.16, 0.17, 0.19, 0.20, 0.22, 0.23, 0.25, 0.26, 0.27, 0.29, 0.30, 0.32, 0.33, 0.35”,
“brakeTorqueOutput”: “0.000, 49.09, 98.18, 166.20, 360.97, 555.75, 937.50, 1327.03, 1754.49, 2195.60, 2653.02, 3313.10, 4377.48, 6691.15, 7438.69”,
“throttlePedalInput”: “0.17, 0.20, 0.23, 0.27, 0.30, 0.34, 0.37, 0.41, 0.44, 0.48, 0.51, 0.55, 0.58, 0.61, 0.65”,
“throttleSpeedInput”: “0.00, 2.14, 4.29, 6.43, 8.57, 10.71, 12.86, 15.00, 17.14, 19.29, 21.43, 23.57, 25.71, 27.86, 30.00”,
“throttleTorqueOutput”: [
“68.96, 22.07, -25.21, -72.83, -120.75, -164.84, -202.53, -225.26, -251.77, -279.48, -280.48, -281.48, -282.48, -283.48, -284.48”,
“707.25, 560.40, 411.69, 261.67, 110.68, 11.85, -67.57, -104.96, -144.60, -184.34, -185.34, -186.34, -187.34, -188.34, -189.34”,
“1342.68, 1096.46, 846.99, 595.26, 341.93, 188.61, 67.71, 15.48, -37.26, -89.02, -98.81, -104.39, -105.39, -106.39, -107.39”,
“1836.76, 1523.81, 1206.73, 886.79, 564.81, 369.49, 214.14, 143.81, 77.25, 13.62, -15.85, -33.79, -34.79, -35.79, -36.79”,
“2328.83, 1949.70, 1565.50, 1177.78, 787.57, 550.43, 360.74, 272.23, 191.87, 116.36, 67.21, 36.91, 35.91, 34.91, 33.91”,
“2678.62, 2266.03, 1848.07, 1426.34, 1001.90, 735.53, 518.64, 408.59, 313.73, 226.45, 159.00, 114.07, 108.81, 102.25, 95.43”,
“3027.80, 2581.90, 2130.32, 1674.71, 1216.19, 920.63, 676.64, 544.97, 435.63, 336.57, 250.81, 191.22, 179.79, 164.42, 147.95”,
“3233.24, 2787.20, 2335.71, 1880.30, 1421.96, 1109.90, 846.17, 689.34, 564.84, 454.13, 351.33, 275.29, 251.74, 221.70, 189.91”,
“3438.51, 2992.44, 2541.10, 2085.90, 1627.74, 1299.14, 1015.83, 833.69, 694.05, 571.68, 451.79, 359.55, 323.67, 278.98, 231.87”,
“3500.25, 3087.18, 2669.66, 2248.71, 1824.99, 1492.50, 1197.24, 986.03, 830.59, 696.67, 560.88, 451.03, 396.57, 331.39, 263.27”,
“3561.46, 3181.47, 2797.88, 2411.33, 2022.21, 1685.83, 1378.89, 1138.38, 967.16, 821.69, 669.98, 542.74, 469.46, 383.76, 294.63”,
“3562.46, 3182.47, 2849.89, 2531.52, 2210.98, 1883.18, 1572.48, 1298.63, 1110.98, 954.07, 787.58, 641.78, 543.30, 431.30, 315.53”,
“3563.46, 3183.47, 2900.93, 2651.17, 2399.66, 2080.50, 1766.55, 1458.97, 1254.90, 1086.56, 905.25, 741.10, 617.14, 478.77, 336.28”,
“3564.46, 3184.47, 2901.93, 2728.73, 2579.98, 2281.72, 1972.84, 1627.12, 1406.01, 1226.35, 1031.34, 847.85, 691.91, 521.45, 346.66”,
“3565.46, 3185.47, 2902.93, 2805.41, 2760.14, 2482.92, 2179.94, 1795.43, 1557.29, 1366.29, 1157.55, 954.91, 766.70, 564.01, 356.82”
“axleFront”: {
“corneringStiffness”: 93534.5234375,
“position”: 2.8499999046325684,
“track”: 1.5820000171661377,
“wheelRadiusLeft”: 0.33059999346733093,
“wheelRadiusRight”: 0.33059999346733093
“axleRear”: {
“corneringStiffness”: 176162.140625,
“position”: 0.0,
“track”: 1.5750000476837158,
“body”: {
“boundingBoxPosition”: [
-1.1089999675750732,
0.0,
0.0
“centerOfMass”: [
1.5946999788284302,
0.0,
0.550000011920929
“height”: 1.4730000495910645,
“inertia”: [
750.0,
3200.0,
3414.201171875
“length”: 4.872000217437744,
“mass”: 2014.4000244140625,
“width”: 2.121000051498413,
“widthWithoutMirrors”: 1.852
“hasCabin”: false,
“name”: “ford fusion 2017”,
“numTrailers”: 0
“version”: 7
