Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Pegasus DevKit (E3550)
other
SDK Manager Version
[*] 1.7.1.8928
other
Host Machine Version
[*] native Ubuntu 18.04
other
Having the following issue with recorder-tui application:
Nvidia_Drive@tegra-ubuntu:/usr/local/driveworks-3.5/tools/capture$ sudo ./recorder-tui /usr/local/driveworks-3.5/data/samples/sensors/camera/camera/rig.json
[sudo] password for Nvidia_Drive:
running recorder-tui with arguments: Namespace(aes_key=None, aes_key_encrypted=None, backend=False, bbr=False, disable_encryption=True, enable_encryption=False, no_mount_check=False, non_interaction=False, remote_dw_path='', rig='/usr/local/driveworks-3.5/data/samples/sensors/camera/camera/rig.json', rsa_key='/home/nvidia/.ssh/recorder-aiinfra.pem', rsa_key_md5=None, skip_init_input=False, tag='NONE')
[24-02-2022 15:41:33] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[24-02-2022 15:41:33] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[24-02-2022 15:41:34] SDK: No resources(.pak) mounted from '/usr/local/driveworks-3.5/data'. Please adjust path or some modules won't function properly.
[24-02-2022 15:41:34] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[24-02-2022 15:41:34] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
Copying rigs and setup code for local...
Platform setup for local...
Backend recorder didn't start, no acknowledgement received
Errors detected during recording
First 100 lines of std error log:
First 100 lines of std out log:
When reporting bugs, please attach full log and files /tmp/recorder-tui-7623/*.log and /tmp/recorder-7623/*.log
WARNING: Forcibly exited. Some data might have been lost!
WARNING: Use q<Enter> to exit gracefully, next time.
