Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
im using a the nv_sensors ros node to capture some camera data. quite basic things.
I added this lines to the code to get the image properties. After every frame i get the sensor properties. The idea is to get these values from each frame.
dwImageProperties imageProperties{}
status = dwSensorCamera_getImageProperties(&imageProperties, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, m_camera[0]);
ROS_INFO("alpha %f, analogGain %f conversionGain %f digitalGain %f exposureDurationUs[0] %f wbGainR %f wbGainG1 %f wbGainG2 %f wbGainB %f sensorTemperature %f", imageProperties.sensorStatistics.meta.analogGain, imageProperties.meta.sensorStatistics.conversionGain, imageProperties.meta.sensorStatistics.digitalGain, imageProperties.meta.sensorStatistics.exposureDurationUs.data[0], imageProperties.meta.sensorStatistics.wbGain[0], imageProperties.meta.sensorStatistics.wbGain[1], imageProperties.meta.sensorStatistics.wbGain[2], imageProperties.meta.sensorStatistics.wbGain[3], imageProperties.meta.sensorStatistics.sensorTemperature.dataCelsius[0]);
and then print them. But the Values are coming out only as 0.
as shown alpha 0.000000, analogGain 0.000000 conversionGain 0.000000 digitalGain 0.000000 exposureDurationUs[0] 0.000000 wbGainR 0.000000 wbGainG1 0.000000 wbGainG2 0.000000 wbGainB 0.000000
i corrected my original code to get the “right” variables in sensor statistics after a couple deprecated warnings. Im currently using DriveOS6.0.6.0-32441545 and Driveworks 5.10. in the SDK from Driveworks 5.14 (which is what i can open rn for some reason i get redirected from 5.10 automatically to 5.14) seems to say these are the variables i would like to know.
In summary, Im trying to get gain, exposure time from the image but all i get are 0, am i doing something wrong? is there a better method to do this or are the values correct somehow and im just visualizing them wrongly?
Best
Yuri
