Dual CSI realtime streaming 4k@60fps on NVIDIA Jetson AGX Orin
Hey NVIDIA!
I want to stream two CSI cameras side by side at 4k60FPS on my Jetson AGX Orin Development Kit.
Currently im using gstreamer and OpenCV in python for this. I also want to set a few key shortcuts for things like digital zoom and pan, and recording from the first camera only at 1080p30fps.
Currently im not getting 60FPS on either streams. Can I get any sugggestions on how to achieve this?
What’s the gst command?
Did you boost the clocks to try?
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
def gstreamer_pipeline(
sensor_id=0,
capture_width=4056,
capture_height=3040,
display_width=1920,
display_height=1080,
framerate=60,
flip_method=0,
return (
f"nvarguscamerasrc sensor-id={sensor_id} ! "
f"video/x-raw(memory:NVMM), width=(int){capture_width}, height=(int){capture_height}, "
f"framerate=(fraction){framerate}/1 ! nvvidconv flip-method={flip_method} ! "
f"video/x-raw, width=(int){display_width}, height=(int){display_height}, format=(string)BGRx ! "
f"videoconvert ! video/x-raw, format=(string)BGR ! appsink"
im using this pipeline
I have boosted clocks, it does not affect the speed. My code is as follows:
import cv2
import threading
import numpy as np
import time
class CSI_Camera:
def init(self):
self.video_capture = None
self.frame = None
self.grabbed = False
self.read_thread = None
self.read_lock = threading.Lock()
self.running = False
self.zoom_factor = 1.0
self.pan_x = 0
self.pan_y = 0
self.last_time = time.time()
self.fps = 0
self.writer = None
self.is_recording = False
def open(self, gstreamer_pipeline_string):
    try:
        self.video_capture = cv2.VideoCapture(
            gstreamer_pipeline_string, cv2.CAP_GSTREAMER
        self.grabbed, self.frame = self.video_capture.read()
        if self.grabbed:
            self.frame_height, self.frame_width = self.frame.shape[:2]
    except RuntimeError:
        print("Unable to open camera")
        print("Pipeline: " + gstreamer_pipeline_string)
def start(self):
    if self.running:
        print('Video capturing is already running')
        return None
    if self.video_capture is not None:
        self.running = True
        self.read_thread = threading.Thread(target=self.updateCamera)
        self.read_thread.start()
    return self
def stop(self):
    if self.read_thread is not None:
        self.read_thread.join()
    if self.is_recording:
        self.stop_recording()
def updateCamera(self):
    while self.running:
        try:
            grabbed, frame = self.video_capture.read()
            if grabbed:
                with self.read_lock:
                    self.grabbed = grabbed
                    self.frame = frame
                    current_time = time.time()
                    self.fps = int(1 / (current_time - self.last_time))
                    self.last_time = current_time
                    if self.is_recording and self.writer is not None:
                        self.writer.write(frame)
            print("Could not read image from camera")
def read(self):
        frame = self.frame.copy() if self.frame is not None else None
        grabbed = self.grabbed
    return grabbed, frame
def release(self):
        self.video_capture.release()
def start_recording(self, filename):
        fourcc = cv2.VideoWriter_fourcc(*'MJPG')
        self.writer = cv2.VideoWriter(filename, fourcc, self.fps, (self.frame_width, self.frame_height))
        self.is_recording = True
def stop_recording(self):
        if self.writer:
            self.writer.release()
            self.writer = None
        time.sleep(0.1)
def apply_zoom_pan(self):
        if self.frame is not None:
            center_x, center_y = int(self.frame.shape[1] / 2), int(self.frame.shape[0] / 2)
            new_width = int(self.frame.shape[1] / self.zoom_factor)
            new_height = int(self.frame.shape[0] / self.zoom_factor)
            x1 = max(min(center_x - new_width // 2 + self.pan_x, self.frame.shape[1] - new_width), 0)
            y1 = max(min(center_y - new_height // 2 + self.pan_y, self.frame.shape[0] - new_height), 0)
            x2 = x1 + new_width
            y2 = y1 + new_height
            cropped_frame = self.frame[y1:y2, x1:x2]
            resized_frame = cv2.resize(cropped_frame, (self.frame.shape[1], self.frame.shape[0]))
            font = cv2.FONT_HERSHEY_SIMPLEX
            cv2.putText(resized_frame, f'FPS: {self.fps}', (10, 30), font, 1, (0, 0, 255), 2, cv2.LINE_AA)
            return resized_frame
        else:
            return None
sensor_id=0,
capture_width=4056,
display_width=1920,
framerate=60,
flip_method=0,
return (
def run_cameras():
window_title = “Dual CSI Cameras”
display_width = 1920
display_height = 2160
left_camera = CSI_Camera()
right_camera = CSI_Camera()
left_camera.open(
    gstreamer_pipeline(
        sensor_id=0,
        capture_width=4056,
        display_width=display_width,
        display_height=display_height,
right_camera.open(
    gstreamer_pipeline(
        sensor_id=1,
        capture_width=4056,
left_camera.start()
right_camera.start()
if left_camera.video_capture.isOpened() and right_camera.video_capture.isOpened():
    cv2.namedWindow(window_title, cv2.WINDOW_NORMAL)
    cv2.resizeWindow(window_title, 3840, 2160)
    try:
        while True:
            _, left_image = left_camera.read()
            _, right_image = right_camera.read()
            left_image = left_camera.apply_zoom_pan()
            right_image = right_camera.apply_zoom_pan()
            if left_image is not None and right_image is not None:
                combined_image = np.hstack((left_image, right_image))
                cv2.imshow(window_title, combined_image)
            keyCode = cv2.waitKey(30) & 0xFF
            if keyCode == ord('z'):
                left_camera.zoom_factor *= 1.1
                right_camera.zoom_factor *= 1.1
            elif keyCode == ord('x'):
                left_camera.zoom_factor /= 1.1
                right_camera.zoom_factor /= 1.1
            elif keyCode == ord('w'):
                left_camera.pan_y -= 10
                right_camera.pan_y -= 10
            elif keyCode == ord('s'):
                left_camera.pan_y += 10
                right_camera.pan_y += 10
            elif keyCode == ord('a'):
                left_camera.pan_x -= 10
                right_camera.pan_x -= 10
            elif keyCode == ord('d'):
                left_camera.pan_x += 10
                right_camera.pan_x += 10
            elif keyCode == ord('r'):
                if not left_camera.is_recording:
                    left_camera.start_recording("output.avi")
            elif keyCode == ord('c'):
                if left_camera.is_recording:
                    left_camera.stop_recording()
            elif keyCode == 27:  # ESC key
                break
    finally:
        left_camera.stop()
        left_camera.release()
        right_camera.stop()
        right_camera.release()
        cv2.destroyAllWindows()
else:
    print("Error: Unable to open both cameras")
    left_camera.stop()
    right_camera.stop()
if name == “main”:
run_cameras()
Please confirm by below command if able get 60fps for both CAM.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=4056,height=3040,framerate=60/1,format=NV12' ! nvvidconv ! fpsdisplaysink video-sink=fakesink -v
gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM),width=4056,height=3040,framerate=60/1,format=NV12' ! nvvidconv ! fpsdisplaysink video-sink=fakesink -v
Yes I am able to. Now i need to display both cameras in a single window. I am currently using OpenCV as you can see in my code. Can you suggest something better that can give me 60fps on both cameras?
Also If i need to record from one of these cameras too, what would be a suitable pipeline for that?
Have reference to below topic.
Check below for the record command.
