I am trying to develop two custom CAMERA SENSOR at the same time .
It was modified as follows with reference to the tegra186-camera-e3323-a00.dtsi file.
I want to use two sensors with the same i2c line and different addresses.
Is there any problem if I modify as below?
i2c@3180000 {
s5k5e8_c@10 {
compatible = "nvidia,s5k5e8";
/* I2C device address */
reg = <0x10>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "4.675";
physical_h = "3.633";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* Sensor output flip settings */
vertical-flip = "false";
mode0 { // S5K5E8_MODE_2608X1960
mclk_khz = "24000";
embedded_metadata_height = "0";
mode1 { //S5K5E8_MODE_1304X980
mclk_khz = "24000";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3327_s5k5e8_out0: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&e3327_csi_in0>;
s5k5e8_d@18 {
reg = <0x18>;
devnode = "video1";
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
mclk_khz = "24000";
mclk_khz = "24000";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3327_s5k5e8_out1: endpoint {
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&e3327_csi_in1>;
