Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
I am writing ROS Driver for Multiple cameras in drive OS 5.2 and driveworks-3.5.
im using dwSensorCamera_readFrameNew() for reading the frames, it works well in one camera but im getting DW_CALL_NOT_ALLOWED error when i read frames of other three cameras. I have initialized and started the cameras without any problem. Can someone tell me what am i doing wrong?
Dear @vimal.prasath .
Could you please share more details about your camera setup, complete error logs and DW sample reproducible code snippet?
Dear @vimal.prasath ,
The error DW_CALL_NOT_ALLOWED indicate it is an invalid call. It looks like a limitation with dwSensorCamera_readFrameNew() API. I will check with core team and get back to you
We have connected the four cameras to csi-a port.
Here is the code i have used to retrieve frames from four cameras.
void SensorCamera::run_camera()
{ dwCameraFrameHandle_t frame[16];
ROS_INFO("inside run_camera ");
ROS_INFO("mcam %d",m_cam);
while(m_cameraRun) {
ImagePtr image(new Image);
dwImageHandle_t cpuFrame;
for(uint32_t i=0;i< m_cam ; ++i)
ROS_INFO("run_camera %d ",i);
dwStatus status = DW_NOT_READY;
uint32_t countFailure = 0;
while ((status == DW_NOT_READY) || (status == DW_END_OF_STREAM))
status = dwSensorCamera_readFrameNew(&frame[i], 333333, m_camera[i]);
countFailure++;
if (countFailure == 1000000)
std::cout << "Camera doesn't seem responsive, exit loop and stopping the sample" << std::endl;
break;
// Reset the sensor to support loopback
if (status == DW_END_OF_STREAM)
dwSensor_reset(m_camera[i]);
std::cout << "Video reached end of stream" << std::endl;
if (status == DW_TIME_OUT)
throw std::runtime_error("onRender: Timeout waiting for camera " + i);
if (status != DW_SUCCESS) {
ROS_ERROR("camera sensor readFrame failed. Error: %s", dwGetStatusName(status));
continue;
dwImageHandle_t img;
dwCameraOutputType outputType = DW_CAMERA_OUTPUT_NATIVE_PROCESSED;
dwStatus status = dwSensorCamera_getImage(&img, outputType, frame[i]);
if(status != DW_SUCCESS) {
ROS_ERROR("Error");
break;
// convert native (yuv420 planar nvmedia) to rgba nvmedia
status = dwImage_copyConvert(m_rgbaFrame[i], img, m_sdk);
ROS_ERROR("Error");
break;
// stream that image to the CPU domain
status = dwImageStreamer_producerSend(m_rgbaFrame[i], m_streamerNvmediaToCpuProcessed[i]);
ROS_ERROR("Error");
break;
// receive the streamed image as a handle
status = dwImageStreamer_consumerReceive(&cpuFrame, 33000, m_streamerNvmediaToCpuProcessed[i]);
ROS_ERROR("Error");
break;
dwImageProperties prop;
status = dwImage_getProperties(&prop, cpuFrame);
ROS_ERROR("dwImage_getProperties() failed. Error: %s", dwGetStatusName(status));
break;
dwImageCPU *imgCPU;
status = dwImage_getCPU(&imgCPU, cpuFrame);
ROS_ERROR("dwImage_getCPU() failed. Error: %s", dwGetStatusName(status));
break;
unsigned int pair_id = 0;
dwTime_t timestamp;
dwImage_getTimestamp(×tamp, img);
image->header.stamp.sec = (timestamp / 1000000L);
image->header.stamp.nsec = (timestamp % 1000000L) * 1000;
ROS_DEBUG("timestamp: %u.%u", image->header.stamp.sec, image->header.stamp.nsec);
image->header.seq = pair_id;
pair_id++;
image->header.frame_id = "camera";
fillImage(*image, sensor_msgs::image_encodings::RGBA8, prop.height, prop.width, 4 * prop.width, imgCPU->data[i]);
status = dwImageStreamer_consumerReturn(&cpuFrame, m_streamerNvmediaToCpuProcessed[i]);
ROS_ERROR("dwImageStreamer_consumerReturn() failed. Error: %s", dwGetStatusName(status));
break;
status = dwImageStreamer_producerReturn(nullptr, 33000, m_streamerNvmediaToCpuProcessed[i]);
ROS_ERROR("dwImageStreamer_producerReturn() failed. Error: %s", dwGetStatusName(status));
break;
dwStatus status = dwSensorCamera_returnFrame(&frame[i]); // error at aceesing and returning multiple frames in a array of i only capable of doing it for 0.
ROS_ERROR("dwSensorCamera_returnFrame Error %d",i);
break;
m_cameraPub[i].publish(image);
Error logs
It seems you have already created separate handle for each camera which is limitation SIPL based camera. Could you check sample_camera sample. It does the same thing as your requirement.
I have gone through the sample_camera sample. even this sample creates separate handle for each camera and i have made the similar thing as well.
Below i have attached the sample_camera code where seperate handle has been created for each cameras
for (uint32_t i = 0; i < cnt; i++)
uint32_t cameraSensorIdx = 0;
CHECK_DW_ERROR(dwRig_findSensorByTypeIndex(&cameraSensorIdx, DW_SENSOR_CAMERA, i, rigConfig));
const char* protocol = nullptr;
CHECK_DW_ERROR(dwRig_getSensorProtocol(&protocol, cameraSensorIdx, rigConfig));
const char* params = nullptr;
CHECK_DW_ERROR(dwRig_getSensorParameterUpdatedPath(¶ms, cameraSensorIdx, rigConfig));
dwSensorParams paramsClient{};
paramsClient.protocol = protocol;
paramsClient.parameters = params;
std::cout << "onInitialize: creating camera.gmsl with params: " << params << std::endl;
CHECK_DW_ERROR(dwSAL_createSensor(&m_camera[m_totalCameras], paramsClient, m_sal));
m_totalCameras++;
m_useRaw = std::string::npos != std::string(params).find("raw");
m_useProcessed = std::string::npos != std::string(params).find("processed");
if (!m_useProcessed && !m_useRaw) //if neither output format specified, assume processed output
m_useProcessed = true;
if (!m_useProcessed)
std::cout << "Processed not selected as master output format parameter. No images will be previewed." << std::endl;
@SivaRamaKrishnaNV
I went through the sample camera code and implemented it the same way but I am getting the same error. I was able to read the frame from one camera but not the other three cameras. is there anything I need to consider before reading the frame. Please let us know.
@SivaRamaKrishnaNV We have solved the issue. Issue was in the initialization of the sensors.
Good to hear that. Please share your mistake to educate others in the community.
@vimal.prasath please share how you solved the problem.
