Unable to read camera frame
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hello, I am trying to read frames from the cameras but I constantly get this error :
[2021-04-23 15:28:38] DW Error DW_CALL_NOT_ALLOWED executing DW function:
 dwSensorCamera_readFrameNew(&camera_frame_handle, 0, sensor_handle)
Here is the code I use :
class Camera {
public:
  dwContextHandle_t context_handle = DW_NULL_HANDLE;
  dwSALHandle_t sal_handle = DW_NULL_HANDLE;
  dwImageProperties image_properties;
  dwCameraProperties camera_properties;
  dwContextParameters sdkParams = {};
  dwInitialize(&context_handle, DW_VERSION, &sdkParams);
  CHECK_DW_ERROR_ROS(dwSAL_initialize(&sal_handle, context_handle));
  dwSensorHandle_t sensor_handle = DW_NULL_HANDLE;
  params_ = "camera-name=SF3324,interface=csi-a,link=1,output-format=processed";
  dwSensorParams sensor_params;
  sensor_params.parameters = params_.c_str();
  sensor_params.protocol = "camera.gmsl";
  CHECK_DW_ERROR_ROS(dwSAL_createSensor(&sensor_handle, sensor_params, sal_handle));
  dwImageProperties imageProperties{};
  CHECK_DW_ERROR_ROS(dwSensorCamera_getImageProperties(&imageProperties, DW_CAMERA_OUTPUT_CUDA_RGBA_UINT8, sensor_handle));
  CHECK_DW_ERROR_ROS(dwSensorCamera_getImageProperties(&image_properties, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, sensor_handle));
  CHECK_DW_ERROR_ROS(dwSensorCamera_getSensorProperties(&camera_properties, sensor_handle));
  dwCameraFrameHandle_t camera_frame_handle;
  dwStatus status = DW_NOT_READY;
  CHECK_DW_ERROR_ROS(dwSensorCamera_readFrameNew(&camera_frame_handle, 0, sensor_handle));
  dwSAL_releaseSensor(sensor_handle);
  dwSAL_release(sal_handle);
  dwRelease(context_handle);
I reproduced the camera sample almost line by line and I don’t understand where this error comes from and what I am doing wrong.
Whjat do you think ?
Thanks a lot for your help !
Found the solution at my problem :
I was not starting the sensor with : dwSensor_start()
Glad to know issue resolve, thanks for the update.
