E-con Systems See3CAM_CU135M freezing on Jetson Orin Nano
Hi everyone!
We are currently fighting random “freezing” of e-con Systems See3CAM_CU135M camera when it is connected to Jetson Orin Nano Dev Kit and we would appreciate any help in debugging this issue!
You can find below the information about our system, more detailed description of this freezing behavior and results of our initial troubleshooting.
System Description:
We are developing a device which core functionality is to capture a sequence of high-resolution images and subsequently post-process it. We need to capture the images with the maximum FPS allowed by the camera and we can’t afford any freezing during the operation.
Jetson Orin Nano Dev Kit:
  • L4T 36.4.3
  • JetPack 6.2 (however, this issue was on earlier SDK versions as well)
e-con Systems See3CAM_CU135M:
  • Frame parameters: 4200x3120 px, 8-bit
  • Connected as USB3.1 device: 20 FPS max, i.e. 2 Gbps bandwidth is required; typical power consumption specified by e-con Systems is 1.2 W
  • Connected as USB2.0 device - 2 FPS max, typical power consumption is 0.8 W
  • Frame readout: free-run camera mode, readout with Python OpenCV, V4L2 API
No other peripheral devices are connected to USB ports.
Freezing behavior:
While used as an USB3.1 device on Jetson Orin Nano, the camera connects and disconnects during operation, for example, during subsequent readout of 100 frames in camera free-run mode. The camera has an LED status indicator which goes from “red” (not in operation) to “yellow” (in operation) several times during data acquisition.
Such behavior is not present while connected to Jetson Nano (from which we are currently migrating) and on both Jetson devices in USB2.0 mode.
System info:
lsusb -t # camera is connected to one of the USB-A ports
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
        |__ Port 2: Dev 3, If 0, Class=Video, Driver=uvcvideo, 5000M
        |__ Port 2: Dev 3, If 1, Class=Video, Driver=uvcvideo, 5000M
        |__ Port 2: Dev 3, If 2, Class=Human Interface Device, Driver=usbhid, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
    |__ Port 3: Dev 3, If 0, Class=Wireless, Driver=rtk_btusb, 12M
    |__ Port 3: Dev 3, If 1, Class=Wireless, Driver=rtk_btusb, 12M
v4l2-ctl --info
Driver Info:
	Driver name      : uvcvideo
	Card type        : See3CAM_CU135M_H03R1
	Bus info         : usb-3610000.usb-1.2
	Driver version   : 5.15.148
	Capabilities     : 0x84a00001
		Video Capture
		Metadata Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Model            : See3CAM_CU135M_H03R1
	Serial           : 2A35D008
	Media version    : 5.15.148
	Hardware revision: 0x00000000 (0)
Interface Info:
	Type             : V4L Video
Entity Info:
	Function         : V4L2 I/O
	Flags            : default
	Pad 0x01000007   : 0: Sink
	  Link 0x02000010: from remote pad 0x100000a of entity 'Extension 3' (Video Pixel Formatter): Data, Enabled, Immutable
v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
	/dev/media0
See3CAM_CU135M_H03R1 (usb-3610000.usb-1.2):
	/dev/video0
	/dev/video1
	/dev/media1
dmesg # full upon reboot with camera module connected
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6336-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Tue Jan 7 17:14:38 PST 2025 ()
[    0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x26d82f198 TPMFinalLog=0x25e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x267144018 ESRT=0x267929398 TPMEventLog=0x25e408018 RNG=0x25a950018 MEMRESERVE=0x25e40ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x0000000267929398 to 0x00000002679293d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x271307800-0x271309fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000277ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000025e240fff]
[    0.000000]   node   0: [mem 0x000000025e241000-0x000000025e3fffff]
[    0.000000]   node   0: [mem 0x000000025e400000-0x000000025e40afff]
[    0.000000]   node   0: [mem 0x000000025e40b000-0x000000025e40bfff]
[    0.000000]   node   0: [mem 0x000000025e40c000-0x000000026b8effff]
[    0.000000]   node   0: [mem 0x000000026b8f0000-0x000000026d82ffff]
[    0.000000]   node   0: [mem 0x000000026d830000-0x0000000271dfffff]
[    0.000000]   node   0: [mem 0x0000000271e00000-0x0000000271ffffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x000000027259ffff]
[    0.000000]   node   0: [mem 0x0000000272f00000-0x0000000272ffffff]
[    0.000000]   node   0: [mem 0x0000000276000000-0x0000000277ffffff]
[    0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[    0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[    0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[    0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[    0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[    0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 2588672
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] mminit::zonelist general 0:DMA = 0:DMA
[    0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[    0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[    0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2001056
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 7517528K/8133248K available (20160K kernel code, 4064K rwdata, 10060K rodata, 7680K init, 529K bss, 353576K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000371] Console: colour dummy device 80x25
[    0.000380] printk: console [tty0] enabled
[    0.000441] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000448] pid_max: default: 32768 minimum: 301
[    0.000486] LSM: Security Framework initializing
[    0.000508] Yama: becoming mindful.
[    0.000527] SELinux:  Initializing.
[    0.000611] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000626] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001739] rcu: Hierarchical SRCU implementation.
[    0.003861] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[    0.004173] Remapping and enabling EFI services.
[    0.004985] smp: Bringing up secondary CPUs ...
[    0.005475] Detected PIPT I-cache on CPU1
[    0.005517] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005553] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.006005] Detected PIPT I-cache on CPU2
[    0.006016] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.006030] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006436] Detected PIPT I-cache on CPU3
[    0.006446] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006459] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008906] Detected PIPT I-cache on CPU4
[    0.008933] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.008961] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009442] Detected PIPT I-cache on CPU5
[    0.009454] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009469] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009528] smp: Brought up 1 node, 6 CPUs
[    0.009532] SMP: Total of 6 processors activated.
[    0.009535] CPU features: detected: 32-bit EL0 Support
[    0.009537] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009540] CPU features: detected: Common not Private translations
[    0.009541] CPU features: detected: CRC32 instructions
[    0.009542] CPU features: detected: Data cache clean to Point of Persistence
[    0.009544] CPU features: detected: Generic authentication (architected algorithm)
[    0.009545] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009546] CPU features: detected: LSE atomic instructions
[    0.009547] CPU features: detected: Privileged Access Never
[    0.009548] CPU features: detected: RAS Extension Support
[    0.009550] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.024920] spectre-bhb mitigation disabled by command line option
[    0.050984] CPU: All CPU(s) started at EL2
[    0.054160] devtmpfs: initialized
[    0.073128] KASLR enabled
[    0.073335] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.073364] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.078401] pinctrl core: initialized pinctrl subsystem
[    0.079415] SMBIOS 3.6.0 present.
[    0.079431] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[    0.079986] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.081920] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.082049] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.082143] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.082256] audit: initializing netlink subsys (disabled)
[    0.082425] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[    0.084063] thermal_sys: Registered thermal governor 'step_wise'
[    0.084067] thermal_sys: Registered thermal governor 'user_space'
[    0.084069] thermal_sys: Registered thermal governor 'power_allocator'
[    0.087921] cpuidle: using governor menu
[    0.088135] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.088239] ASID allocator initialised with 32768 entries
[    0.090254] Serial: AMBA PL011 UART driver
[    0.101580] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.113091] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.122226] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.122232] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.122233] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.122234] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.123278] cryptd: max_cpu_qlen set to 1000
[    0.125326] ACPI: Interpreter disabled.
[    0.126517] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.126651] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.126866] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.127295] iommu: Default domain type: Translated
[    0.127300] iommu: DMA domain TLB invalidation policy: strict mode
[    0.127609] SCSI subsystem initialized
[    0.127697] libata version 3.00 loaded.
[    0.127809] vgaarb: loaded
[    0.127976] usbcore: registered new interface driver usbfs
[    0.127999] usbcore: registered new interface driver hub
[    0.128013] usbcore: registered new device driver usb
[    0.128429] pps_core: LinuxPPS API ver. 1 registered
[    0.128436] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.128447] PTP clock support registered
[    0.128528] EDAC MC: Ver: 3.0.0
[    0.129603] Registered efivars operations
[    0.130217] FPGA manager framework
[    0.130318] Advanced Linux Sound Architecture Driver Initialized.
[    0.130837] Bluetooth: Core ver 2.22
[    0.130863] NET: Registered PF_BLUETOOTH protocol family
[    0.130867] Bluetooth: HCI device and connection manager initialized
[    0.130876] Bluetooth: HCI socket layer initialized
[    0.130882] Bluetooth: L2CAP socket layer initialized
[    0.130895] Bluetooth: SCO socket layer initialized
[    0.131302] clocksource: Switched to clocksource arch_sys_counter
[    0.165720] VFS: Disk quotas dquot_6.6.0
[    0.165791] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.166021] pnp: PnP ACPI: disabled
[    0.169026] NET: Registered PF_INET protocol family
[    0.169341] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.170858] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.170955] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.170985] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.171074] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.172454] TCP: Hash tables configured (established 65536 bind 65536)
[    0.172611] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.172641] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.172837] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.173266] RPC: Registered named UNIX socket transport module.
[    0.173270] RPC: Registered udp transport module.
[    0.173272] RPC: Registered tcp transport module.
[    0.173273] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.173292] PCI: CLS 0 bytes, default 64
[    0.173597] Unpacking initramfs...
[    0.180629] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.181031] kvm [1]: IPA Size Limit: 48 bits
[    0.181072] kvm [1]: GICv3: no GICV resource entry
[    0.181081] kvm [1]: disabling GICv2 emulation
[    0.181102] kvm [1]: GIC system register CPU interface enabled
[    0.181177] kvm [1]: vgic interrupt IRQ9
[    0.181333] kvm [1]: VHE mode initialized successfully
[    0.184302] Initialise system trusted keyrings
[    0.184347] Key type blacklist registered
[    0.184489] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.188108] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.188534] NFS: Registering the id_resolver key type
[    0.188560] Key type id_resolver registered
[    0.188562] Key type id_legacy registered
[    0.188612] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.188625] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.188651] ntfs: driver 2.1.32 [Flags: R/O].
[    0.188862] 9p: Installing v9fs 9p2000 file system support
[    0.189484] integrity: Platform Keyring initialized
[    0.202441] Key type asymmetric registered
[    0.202451] Asymmetric key parser 'x509' registered
[    0.202574] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.202582] io scheduler mq-deadline registered
[    0.202590] io scheduler kyber registered
[    0.213376] EINJ: ACPI disabled.
[    0.225615] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.227460] SuperH (H)SCI(F) driver initialized
[    0.227784] msm_serial: driver initialized
[    0.228514] printk: console [ttyTCU0] enabled
[    0.229492] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.229498] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.229507] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.229511] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.229514] arm-smmu 8000000.iommu: 	nested translation
[    0.229523] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.229528] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.229540] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.229542] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.229545] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.230594] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.230600] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.230601] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.230602] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.230603] arm-smmu 10000000.iommu: 	nested translation
[    0.230606] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.230608] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.230617] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.230618] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.230619] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.231005] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.231009] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.231011] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.231011] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.231013] arm-smmu 12000000.iommu: 	nested translation
[    0.231015] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.231017] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.231021] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.231023] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.231025] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.238283] loop: module loaded
[    0.239112] megasas: 07.717.02.00-rc1
[    0.243060] tun: Universal TUN/TAP device driver, 1.6
[    0.243671] thunder_xcv, ver 1.0
[    0.243704] thunder_bgx, ver 1.0
[    0.243728] nicpf, ver 1.0
[    0.244554] hclge is initializing
[    0.244585] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.244594] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.244634] e1000: Intel(R) PRO/1000 Network Driver
[    0.244639] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.244668] e1000e: Intel(R) PRO/1000 Network Driver
[    0.244674] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.244698] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.244703] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.244719] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.244725] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.244959] sky2: driver version 1.30
[    0.245634] VFIO - User Level meta-driver version: 0.3
[    0.247305] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.247314] ehci-pci: EHCI PCI platform driver
[    0.247348] ehci-platform: EHCI generic platform driver
[    0.247430] ehci-orion: EHCI orion driver
[    0.247495] ehci-exynos: EHCI Exynos driver
[    0.247570] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.247594] ohci-pci: OHCI PCI platform driver
[    0.247617] ohci-platform: OHCI generic platform driver
[    0.247690] ohci-exynos: OHCI Exynos driver
[    0.248131] usbcore: registered new interface driver usb-storage
[    0.249927] i2c_dev: i2c /dev entries driver
[    0.251242] pps pps0: new PPS source ktimer
[    0.251252] pps pps0: ktimer PPS source registered
[    0.251260] pps_ldisc: PPS line discipline registered
[    0.253379] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.255332] sdhci: Secure Digital Host Controller Interface driver
[    0.255336] sdhci: Copyright(c) Pierre Ossman
[    0.255799] Synopsys Designware Multimedia Card Interface Driver
[    0.256418] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.257573] ledtrig-cpu: registered to indicate activity on CPUs
[    0.258555] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.259149] tegra-bpmp bpmp: Adding to iommu group 0
[    0.260533] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[    0.446626] Freeing initrd memory: 15480K
[    3.869207] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.869232] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.869236] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.869463] hid: raw HID events driver (C) Jiri Kosina
[    3.869868] usbcore: registered new interface driver usbhid
[    3.869872] usbhid: USB HID core driver
[    3.875279] optee: probing for conduit method.
[    3.875342] optee: revision 4.2 (d78bc5fa)
[    3.935313] optee: dynamic shared memory is enabled
[    3.935590] optee: initialized driver
[    3.938700] usbcore: registered new interface driver snd-usb-audio
[    3.940468] NET: Registered PF_PACKET protocol family
[    3.941598] Bluetooth: RFCOMM TTY layer initialized
[    3.941635] Bluetooth: RFCOMM socket layer initialized
[    3.941703] Bluetooth: RFCOMM ver 1.11
[    3.942014] 9pnet: Installing 9P2000 support
[    3.942134] Key type dns_resolver registered
[    3.943693] printk: console [tty0]: printing thread started
[    3.944880] printk: console [ttyTCU0]: printing thread started
[    3.945030] Loading compiled-in X.509 certificates
[    3.949652] Loaded X.509 cert 'Build time autogenerated kernel key: 6ad7eb1abc7541e974a48fc505964410c4019a6e'
[    3.980169] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.981585] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.982900] serial-tegra 3100000.serial: RX in PIO mode
[    3.982905] serial-tegra 3100000.serial: TX in PIO mode
[    3.982963] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.983485] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    3.985361] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.985373] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.985799] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.989322] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.991358] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.993281] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.994964] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.995549] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.017768] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1766000 KHz, changing to: 1728000 KHz
[    4.022489] tegra-xusb 3610000.usb: Adding to iommu group 2
[    4.038516] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    4.038525] tegra-xusb 3610000.usb: xHCI Host Controller
[    4.038539] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    4.039272] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    4.039304] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[    4.039433] tegra-xusb 3610000.usb: xHCI Host Controller
[    4.039436] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    4.039440] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    4.039917] hub 1-0:1.0: USB hub found
[    4.039931] hub 1-0:1.0: 4 ports detected
[    4.040192] hub 2-0:1.0: USB hub found
[    4.040203] hub 2-0:1.0: 4 ports detected
[    4.041773] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    4.042810] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[    4.042871] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.042939] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.044336] sdhci-tegra 3400000.mmc: Got CD GPIO
[    4.091059] ALSA device list:
[    4.091064]   No soundcards found.
[    4.136937] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.137461] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    4.138372] Freeing unused kernel memory: 7680K
[    4.138453] Run /init as init process
[    4.138455]   with arguments:
[    4.138456]     /init
[    4.138457]   with environment:
[    4.138457]     HOME=/
[    4.138458]     TERM=linux
[    4.138459]     bl_prof_dataptr=2031616@0x271E10000
[    4.138460]     bl_prof_ro_ptr=65536@0x271E00000
[    4.149784] Checking overlayfs setting...
[    4.159071] Overlayfs is disabled...
[    4.163692] Root device found: mmcblk0p1
[    4.375297] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    4.546181] hub 1-2:1.0: USB hub found
[    4.547280] hub 1-2:1.0: 4 ports detected
[    4.567736] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[    4.568196] mmcblk0: mmc0:aaaa SR512 477 GiB
[    4.578091]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    4.660452] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    4.707922] hub 2-1:1.0: USB hub found
[    4.709515] hub 2-1:1.0: 4 ports detected
[    4.815296] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    5.407703] usb 2-1.2: new SuperSpeed USB device number 3 using tegra-xusb
[    5.429429] usb 2-1.2: LPM exit latency is zeroed, disabling LPM.
[    5.433974] hid-generic 0003:2560:C1D8.0001: hidraw0: USB HID v1.11 Device [e-con systems See3CAM_CU135M_H03R1] on usb-3610000.usb-1.2/input2
[    7.975868] Found dev node: /dev/mmcblk0p1
[    8.234092] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.242107] Rootfs mounted over mmcblk0p1
[    8.269258] Switching from initrd to actual rootfs
[    8.509819] systemd[1]: System time before build time, advancing clock.
[    8.574965] NET: Registered PF_INET6 protocol family
[    8.575894] Segment Routing with IPv6
[    8.575905] In-situ OAM (IOAM) with IPv6
[    8.613978] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.614341] systemd[1]: Detected architecture arm64.
[    8.615925] systemd[1]: Hostname set to <orin3>.
[    8.631399] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.631417] systemd[1]: Set hardware watchdog to 2min.
[    8.972789] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[    8.995956] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.001455] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.071714] systemd[1]: Queued start job for default target Graphical Interface.
[    9.073615] systemd[1]: Created slice Slice /system/modprobe.
[    9.074360] systemd[1]: Created slice Slice /system/serial-getty.
[    9.074975] systemd[1]: Created slice Slice /system/systemd-fsck.
[    9.075509] systemd[1]: Created slice User and Session Slice.
[    9.076953] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.077335] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.077514] systemd[1]: Reached target Slice Units.
[    9.077573] systemd[1]: Reached target Mounting snaps.
[    9.077630] systemd[1]: Reached target Swaps.
[    9.077684] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.077835] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    9.078063] systemd[1]: Listening on LVM2 poll daemon socket.
[    9.082787] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.083185] systemd[1]: Listening on Syslog Socket.
[    9.083434] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.083945] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.084301] systemd[1]: Listening on Journal Audit Socket.
[    9.084490] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.084724] systemd[1]: Listening on Journal Socket.
[    9.085015] systemd[1]: Listening on udev Control Socket.
[    9.085186] systemd[1]: Listening on udev Kernel Socket.
[    9.086413] systemd[1]: Mounting Huge Pages File System...
[    9.087745] systemd[1]: Mounting POSIX Message Queue File System...
[    9.130522] systemd[1]: Mounting Kernel Debug File System...
[    9.131989] systemd[1]: Mounting Kernel Trace File System...
[    9.143823] systemd[1]: Starting Journal Service...
[    9.144139] systemd[1]: Finished Availability of block devices.
[    9.145755] systemd[1]: Starting Set the console keyboard layout...
[    9.147537] systemd[1]: Starting Create List of Static Device Nodes...
[    9.166455] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    9.168109] systemd[1]: Starting Load Kernel Module configfs...
[    9.182820] systemd[1]: Starting Load Kernel Module drm...
[    9.185516] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.194150] systemd[1]: Starting Load Kernel Module fuse...
[    9.195783] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.206787] systemd[1]: Started Nameserver information manager.
[    9.207061] systemd[1]: Reached target Preparation for Network.
[    9.207399] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.218589] systemd[1]: Starting Load Kernel Modules...
[    9.233273] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.234844] systemd[1]: Starting Coldplug All udev Devices...
[    9.237359] systemd[1]: Started Journal Service.
[    9.241106] fuse: init (API version 7.34)
[    9.246328] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[    9.261517] nvsciipc: loading out-of-tree module taints kernel.
[    9.262484] nvsciipc: loaded module
[    9.285376] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.285996] nvmap_page_pool_init: Total RAM pages: 1950708
[    9.286000] nvmap_page_pool_init: nvmap page pool size: 243838 pages (952 MB)
[    9.286076] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.286405] systemd-journald[235]: Received client request to flush runtime journal.
[    9.315734] tegra-host1x 13e00000.host1x: Adding to iommu group 4
[    9.316514] host1x-context host1x-ctx.0: Adding to iommu group 5
[    9.316661] host1x-context host1x-ctx.1: Adding to iommu group 6
[    9.316800] host1x-context host1x-ctx.2: Adding to iommu group 7
[    9.316953] host1x-context host1x-ctx.3: Adding to iommu group 8
[    9.317157] host1x-context host1x-ctx.4: Adding to iommu group 9
[    9.317290] host1x-context host1x-ctx.5: Adding to iommu group 10
[    9.317421] host1x-context host1x-ctx.6: Adding to iommu group 11
[    9.317562] host1x-context host1x-ctx.7: Adding to iommu group 12
[    9.317690] host1x-context host1x-ctx.8: Adding to iommu group 13
[    9.317828] host1x-context host1x-ctx.9: Adding to iommu group 14
[    9.317945] host1x-context host1x-ctx.10: Adding to iommu group 15
[    9.318064] host1x-context host1x-ctx.11: Adding to iommu group 16
[    9.318184] host1x-context host1x-ctx.12: Adding to iommu group 17
[    9.318309] host1x-context host1x-ctx.13: Adding to iommu group 18
[    9.318417] host1x-context host1x-ctx.14: Adding to iommu group 19
[    9.318538] host1x-context host1x-ctx.15: Adding to iommu group 20
[    9.417847] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.593747] mc: Linux media interface: v0.10
[    9.595557] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: Adding to iommu group 21
[    9.607937] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.623777] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: Adding to iommu group 22
[    9.624774] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 23
[    9.627886] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.637817] scare-pigeon 13e00000.host1x:isp-thi@14b00000: Adding to iommu group 24
[    9.638676] videodev: Linux video capture interface: v2.00
[    9.642098] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.699821] Inserting ivc_ext.ko module
[    9.712719] tegra-vic 15340000.vic: Adding to iommu group 25
[    9.751231] tegra-nvdec 15480000.nvdec: Adding to iommu group 26
[    9.774291] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 27
[    9.778365] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    9.781482] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 28
[    9.785396] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 29
[    9.788168] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[    9.791425] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    9.794962] tegra-ofa 15a50000.ofa: Adding to iommu group 30
[    9.795551] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[    9.799624] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[    9.802493] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[    9.803920] drm drm: [drm] Cannot find any crtc or sizes
[    9.804687] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[    9.806493] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[    9.809316] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (219)
[    9.809321] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    9.809750] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[    9.810088] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[    9.810091] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[    9.810093] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[    9.810095] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[    9.810096] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[    9.810097] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[    9.813318] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[    9.831325] [RCE] TCU debug prints will be routed to traces.
[   10.148216] tegra194-isp5 14800000.isp: Adding to iommu group 24
[   10.151466] driver not enabled, cannot register any devices
[   10.152697] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 21
[   10.158031] driver not enabled, cannot register any devices
[   10.160705] driver not enabled, cannot register any devices
[   10.160705] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 22
[   10.162574] (NULL device *): fops function table already registered
[   10.173727] driver not enabled, cannot register any devices
[   10.220738] tegra-dce d800000.dce: Adding to iommu group 31
[   10.222775] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[   10.222932] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[   10.225216] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[   10.225589] dce: tegra_dce_probe:245  Found display consumer device
[   10.225935] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.225942] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.226197] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[   10.226404] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   10.226410] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[   10.226411] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[   10.226606] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[   10.226611] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[   10.227593] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[   10.233420] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[   10.276486] spi-tegra114 3210000.spi: Adding to iommu group 1
[   10.276792] nv_platform 13800000.display: Adding to iommu group 32
[   10.298666] platform 13800000.display:nvdisplay-niso: Adding to iommu group 33
[   10.299963] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[   10.300375] at24 0-0057: 256 byte 24c02 EEPROM, read-only
[   10.309610] spi-tegra114 3230000.spi: Adding to iommu group 1
[   10.454851] tegra-xudc 3550000.usb: Adding to iommu group 34
[   10.459810] tegra-hda 3510000.hda: Adding to iommu group 35
[   10.461870] tegra194-pcie 14100000.pcie: Adding to iommu group 36
[   10.465644] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[   10.465664] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[   10.465678] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[   10.465689] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[   10.465994] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[   10.465999] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   10.482119] tegra234-aon c000000.aon: Adding to iommu group 37
[   10.483619]  c000000.aon:hsp: probed
[   10.485659] tegra234-aon c000000.aon: init done
[   10.487537] CAN device driver interface
[   10.510304] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   10.510796] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[   10.510915] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[   10.510979] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[   10.511035] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[   10.511957] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   10.514175] thermal-trip-event cv0-throttle-alert: cooling device registered.
[   10.516101] thermal-trip-event cv1-throttle-alert: cooling device registered.
[   10.516340] thermal-trip-event cv2-throttle-alert: cooling device registered.
[   10.516524] thermal-trip-event soc0-throttle-alert: cooling device registered.
[   10.516692] thermal-trip-event soc1-throttle-alert: cooling device registered.
[   10.516892] thermal-trip-event soc2-throttle-alert: cooling device registered.
[   10.518848] thermal-trip-event hot-surface-alert: cooling device registered.
[   10.524746] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[   10.524807] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[   10.540510] TT CAN feature is not supported
[   10.541057] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[   10.542568] Release 3.2.3 from 09.06.2018
[   10.542881] net can0: mttcan device registered (regs=0000000064edd765, irq=201)
[   10.546739] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[   10.547255] fusb301 1-0025: device id: 0x12
[   10.571327] tegra194-pcie 14100000.pcie: Link up
[   10.572836] tegra194-pcie 14100000.pcie: Link up
[   10.572962] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[   10.572968] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[   10.572972] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[   10.572976] pci_bus 0001:00: root bus resource [bus 00-ff]
[   10.572978] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[   10.573030] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[   10.573229] pci 0001:00:00.0: PME# supported from D0 D3hot
[   10.578038] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[   10.578214] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   10.578416] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[   10.579508] pci 0001:01:00.0: supports D1 D2
[   10.579512] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   10.584723] fusb301 1-0025: toggle_time(0) is not updated
[   10.585063] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[   10.585398] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[   10.585403] fusb301 1-0025: fusb_update_state: 1
[   10.586821] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[   10.594682] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[   10.594698] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[   10.594703] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[   10.594811] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[   10.594842] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[   10.594846] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[   10.594850] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[   10.595023] pcieport 0001:00:00.0: Adding to iommu group 36
[   10.595151] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[   10.595281] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[   10.596472] tegra194-pcie 14160000.pcie: Adding to iommu group 38
[   10.600166] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[   10.600194] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[   10.600201] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[   10.600205] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[   10.600527] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[   10.600530] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   10.645249] usbcore: registered new interface driver btusb
[   10.754640] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.6fd4e69.20220818-105856
[   10.754649] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   10.754651] rtk_btcoex: create workqueue
[   10.754875] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   10.757206] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[   10.757210] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[   10.757212] rtk_btusb: patch_add
[   10.757214] rtk_btusb: auto suspend is disabled
[   10.757216] rtk_btusb: pid = 0x3549
[   10.757219] rtk_btusb: patch_add: Reset gEVersion to 0xff
[   10.757227] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[   10.776190] rtk_btusb: btusb_probe: done
[   10.777262] rtk_btusb: btusb_open start
[   10.777269] rtk_btusb: btusb_open hdev->promisc ==0
[   10.777270] rtk_btusb: download_patch start
[   10.777271] rtk_btusb: chip type value: 0x73
[   10.778961] rtk_btusb: chip_type->status = 0x0, chip_type->chip = 0xbeef
[   10.778966] rtk_btusb: HCI reset.
[   10.787412] usbcore: registered new interface driver rtk_btusb
[   10.789949] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[   10.789953] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[   10.789954] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   10.789956] rtk_btusb: load_firmware start
[   10.789956] rtk_btusb: lmp_version = 0x8822
[   10.789957] rtk_btusb: config filename rtl8822cu_config
[   10.792523] usb 2-1.2: Found UVC 1.00 device See3CAM_CU135M_H03R1 (2560:c1d8)
[   10.800751] rtk_btusb: no bdaddr file /opt/bdaddr
[   10.800758] rtk_btusb: Origin cfg len 6
[   10.800760] rtk_btusb: 55 ab 23 87 00 00
[   10.800762] rtk_btusb: New cfg len 6
[   10.800763] rtk_btusb: 55 ab 23 87 00 00
[   10.800770] rtk_btusb: fw name is  rtl8822cu_fw
[   10.808317] rtk_btusb: This is not 8723a, use new patch style!
[   10.808326] rtk_btusb: rtk_get_eversion: gEVersion 255
[   10.809996] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[   10.810006] rtk_btusb: load_firmware: New gEVersion 3
[   10.810008] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[   10.810010] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[   10.810012] rtk_btusb: fw_version = 0x9a8cbc9
[   10.810013] rtk_btusb: number_of_total_patch = 3
[   10.810014] rtk_btusb: chipID 4
[   10.810016] rtk_btusb: patch_length 0x8590
[   10.810016] rtk_btusb: start_offset 0x00005d00
[   10.810018] rtk_btusb: Svn version: 1940234490
[   10.810019] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[   10.810021] rtk_btusb: buf_len = 0x8596
[   10.810033] rtk_btusb: fw: exists, config file: exists
[   10.810035] rtk_btusb: load_firmware done
[   10.810055] rtk_btusb: download_data start
[   10.883807] input: See3CAM_CU135M_H03R1 as /devices/platform/bus@0/3610000.usb/usb2/2-1/2-1.2/2-1.2:1.0/input/input5
[   10.887751] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   10.888850] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2025-01-24T11:20:16 UTC (1737717616)
[   10.891996] usbcore: registered new interface driver uvcvideo
[   10.978962] rtk_btusb: download_data done
[   10.978969] rtk_btusb: HCI reset.
[   10.989952] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   10.989961] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   10.989963] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   10.989970] rtk_btusb: Rtk patch end 0
[   10.989973] rtk_btusb: btusb_open set HCI UP RUNNING
[   10.990005] rtk_btcoex: Open BTCOEX
[   10.990009] rtk_btcoex: rtk_vendor_cmd_to_fw: opcode 0xfc1b
[   10.990018] rtk_btusb: btusb_open end
[   10.993989] rtk_btcoex: unknown hci command
[   10.995965] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   10.995970] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   11.015953] rtk_btusb: btusb_notify: hci0 evt 3
[   11.042325] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   11.076114] loop0: detected capacity change from 0 to 8
[   11.077424] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   11.078167] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   11.078382] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   11.078785] loop1: detected capacity change from 0 to 354856
[   11.088362] loop2: detected capacity change from 0 to 140976
[   11.095516] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[   11.095525] unable to read xattr id index table
[   11.127869] loop3: detected capacity change from 0 to 132448
[   11.183597] loop4: detected capacity change from 0 to 989864
[   11.206420] tegra210-admaif 290f000.admaif: Adding to iommu group 39
[   11.218672] loop5: detected capacity change from 0 to 1010608
[   11.228569] rtl88x2ce 0001:01:00.0: Adding to iommu group 36
[   11.228724] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   11.232391] loop6: detected capacity change from 0 to 187776
[   11.236034] loop7: detected capacity change from 0 to 79232
[   11.284999] rtl88x2ce 0001:01:00.0 wlP1p1s0: renamed from wlan0
[   11.699307] tegra194-pcie 14160000.pcie: Phy link never came up
[   12.700321] tegra194-pcie 14160000.pcie: Phy link never came up
[   12.700461] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[   12.700467] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[   12.700471] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[   12.700475] pci_bus 0004:00: root bus resource [bus 00-ff]
[   12.700477] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[   12.700534] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[   12.700713] pci 0004:00:00.0: PME# supported from D0 D3hot
[   12.706969] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[   12.707171] pcieport 0004:00:00.0: Adding to iommu group 38
[   12.707328] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[   12.707567] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[   12.707953] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[   12.708248] pci 0004:00:00.0: Removing from iommu group 38
[   12.708265] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[   12.710089] tegra194-pcie 141e0000.pcie: Adding to iommu group 40
[   12.712359] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[   12.712384] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[   12.712393] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[   12.712399] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[   12.712751] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[   12.712754] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   13.055509] rtk_btusb: btusb_flush add delay
[   13.065572] rtk_btusb: btusb_close
[   13.076516] rtk_btcoex: Close BTCOEX
[   13.076523] rtk_btcoex: -x
[   13.799312] tegra194-pcie 141e0000.pcie: Phy link never came up
[   14.284813] using random self ethernet address
[   14.284821] using random host ethernet address
[   14.427625] loop8: detected capacity change from 0 to 32768
[   14.447433] nv_nvsciipc_init.sh[712]: found /dev/nvsciipc
[   14.505736] nvsciipc: set_db start
[   14.505787] nvsciipc: set_db done
[   14.799344] tegra194-pcie 141e0000.pcie: Phy link never came up
[   14.799490] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[   14.799496] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[   14.799501] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[   14.799506] pci_bus 0007:00: root bus resource [bus 00-ff]
[   14.799509] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[   14.799563] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[   14.799727] pci 0007:00:00.0: PME# supported from D0 D3hot
[   14.805864] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[   14.806078] pcieport 0007:00:00.0: Adding to iommu group 40
[   14.806212] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[   14.806859] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[   14.807322] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[   14.810308] pci 0007:00:00.0: Removing from iommu group 40
[   14.810337] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[   14.813181] tegra194-pcie 140a0000.pcie: Adding to iommu group 41
[   14.816826] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.816833] Bluetooth: BNEP filters: protocol multicast
[   14.816845] Bluetooth: BNEP socket layer initialized
[   14.830812] Mass Storage Function, version: 2009/09/11
[   14.830820] LUN: removable file: (no medium)
[   14.862742] NET: Registered PF_ALG protocol family
[   14.863241] using random self ethernet address
[   14.863244] using random host ethernet address
[   14.920909] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[   14.920988] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[   14.921007] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[   14.921016] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[   14.921510] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[   14.921515] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   14.967005] rtk_btusb: btusb_open start
[   14.967023] rtk_btusb: btusb_open hdev->promisc ==0
[   14.967026] rtk_btusb: download_patch start
[   14.967030] rtk_btusb: chip type value: 0x73
[   14.968953] rtk_btusb: chip_type->status = 0x0, chip_type->chip = 0xbeef
[   14.968965] rtk_btusb: HCI reset.
[   14.979958] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   14.979973] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   14.979975] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   14.979977] rtk_btusb: Firmware already exists
[   14.979985] rtk_btusb: Rtk patch end 1
[   14.979994] rtk_btusb: btusb_open set HCI UP RUNNING
[   14.980067] rtk_btcoex: Open BTCOEX
[   14.980081] rtk_btcoex: rtk_vendor_cmd_to_fw: opcode 0xfc1b
[   14.980106] rtk_btusb: btusb_open end
[   14.982008] rtk_btcoex: unknown hci command
[   14.984021] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   14.984030] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   15.018105] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   15.031330] tegra194-pcie 140a0000.pcie: Link up
[   15.032776] tegra194-pcie 140a0000.pcie: Link up
[   15.032893] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   15.032899] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[   15.032903] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[   15.032908] pci_bus 0008:00: root bus resource [bus 00-ff]
[   15.032910] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[   15.033014] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[   15.033172] pci 0008:00:00.0: PME# supported from D0 D3hot
[   15.033509] usb0: HOST MAC f2:0c:aa:03:2d:0c
[   15.033516] usb0: MAC f2:0c:aa:03:2d:0d
[   15.034093] usb1: HOST MAC f2:0c:aa:03:2d:0e
[   15.034097] usb1: MAC f2:0c:aa:03:2d:0f
[   15.036604] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[   15.037414] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[   15.037576] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   15.037760] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[   15.037901] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[   15.038888] pci 0008:01:00.0: supports D1 D2
[   15.038890] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   15.047397] l4tbr0: port 1(usb0) entered blocking state
[   15.047416] l4tbr0: port 1(usb0) entered disabled state
[   15.047581] device usb0 entered promiscuous mode
[   15.054705] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[   15.054719] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[   15.054725] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[   15.054819] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[   15.054912] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[   15.054941] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[   15.054944] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[   15.054949] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[   15.055181] pcieport 0008:00:00.0: Adding to iommu group 41
[   15.055379] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[   15.055992] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[   15.059598] l4tbr0: port 2(usb1) entered blocking state
[   15.059617] l4tbr0: port 2(usb1) entered disabled state
[   15.060295] device usb1 entered promiscuous mode
[   15.090683] r8168 0008:01:00.0: Adding to iommu group 41
[   15.090818] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[   15.090898] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   15.108923] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   15.111007] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   15.111200] loop8: detected capacity change from 0 to 32768
[   15.130166] r8168 0008:01:00.0 enP8p1s0: renamed from eth0
[   15.630907] enP8p1s0: 0xffff80000b2c4000, 48:b0:2d:eb:ea:9b, IRQ 269
[   16.926402] pstore: Using crash dump compression: deflate
[   16.926484] printk: console [ramoops-1]: printing thread started
[   16.926503] printk: console [ramoops-1] enabled
[   16.926504] pstore: Registered ramoops as persistent store backend
[   16.926506] ramoops: using 0x200000@0x2725f0000, ecc: 0
[   17.125571] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   17.383821] zram: Added device: zram0
[   17.384041] zram: Added device: zram1
[   17.384239] zram: Added device: zram2
[   17.384402] zram: Added device: zram3
[   17.384618] zram: Added device: zram4
[   17.388273] zram: Added device: zram5
[   17.518182] zram0: detected capacity change from 0 to 1300472
[   17.640088] Adding 650232k swap on /dev/zram0.  Priority:5 extents:1 across:650232k SS
[   17.641517] zram1: detected capacity change from 0 to 1300472
[   17.647488] Adding 650232k swap on /dev/zram1.  Priority:5 extents:1 across:650232k SS
[   17.648688] zram2: detected capacity change from 0 to 1300472
[   17.654569] Adding 650232k swap on /dev/zram2.  Priority:5 extents:1 across:650232k SS
[   17.655745] zram3: detected capacity change from 0 to 1300472
[   17.661367] Adding 650232k swap on /dev/zram3.  Priority:5 extents:1 across:650232k SS
[   17.662516] zram4: detected capacity change from 0 to 1300472
[   17.669104] Adding 650232k swap on /dev/zram4.  Priority:5 extents:1 across:650232k SS
[   17.670305] zram5: detected capacity change from 0 to 1300472
[   17.675948] Adding 650232k swap on /dev/zram5.  Priority:5 extents:1 across:650232k SS
[   19.149508] loop9: detected capacity change from 0 to 8
[   20.033472] ACK 04 d4
[   20.037535] ACK 04 d4
[   20.054141] IPv6: ADDRCONF(NETDEV_CHANGE): wlP1p1s0: link becomes ready
[   20.603756] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.4.0  Release Build  (buildbrain@mobile-u64-6336-d8000)  Tue Jan  7 17:35:14 PST 2025
[   20.613693] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   20.900671] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   20.914505] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   20.916055] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
[   22.557207] audit: type=1326 audit(1737717628.164:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1988 comm="cupsd" exe="/snap/cups/1069/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffffaa08910c code=0x50000
[   23.322212] audit: type=1326 audit(1737717628.928:3): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1988 comm="cupsd" exe="/snap/cups/1069/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffffaa08910c code=0x50000
[   23.345177] audit: type=1326 audit(1737717628.952:4): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2154 comm="cups-browsed" exe="/snap/cups/1069/sbin/cups-browsed" sig=0 arch=c00000b7 syscall=274 compat=0 ip=0xffffb06d1c28 code=0x50000
[   25.249498] rfkill: input handler disabled
dmesg --follow # upon frame readout with freezing
[ 1133.434588] uvcvideo 2-1.2:1.1: Non-zero status (-71) in video completion handler.
[ 1156.839907] uvcvideo 2-1.2:1.1: Non-zero status (-71) in video completion handler.
We also previously observed
uvcvideo: Failed to resubmit video URB (-1).
message but couldn’t reproduce it.
Troubleshooting attempts
  • Following this topic, we tested See3CAM_CU135M camera on both USB-A and USB-C ports of Jetson Orin Nano. The freezing was observed on all available ports on two different Orin Nano Dev Kits.
  • Following several previous topics (e.g. this and this), we tried connecting the camera to a USB hub with external power supply (Conceptronic HUBBIES20GP) but it didn’t fix the problem.
  • We used readily available USB tester which only supports USB2.0 communication, therefore, it is only partially helpful for this issue. We received the following readings for available devices:
    - Jetson Nano: V = 5.10 V, I = 900-1000 mA, P = 0.50 mW
    - Jetson Orin: V = 5.08 V, I = 700 mA, P = 0.35 mW
    - Jetson Orin + USB hub: V = 5.20 V, I = 600-700 mA, P = 0.37 mW
    which still doesn’t correspond to the expected 0.8 W power consumption in the USB2.0 mode.
    Edit: most probably 0.5 mW Nano vs 0.8 mW camera specs power discrepancy can be attributed to the idle power consumption of the USB tester.
  • Following this topic, we also disabled autosuspend and increased allocated memory with no positive results.
At the moment, we have very much exhausted our troubleshooting ideas and would be glad to receive any input from the NVIDIA Support Team or community members!
I would suggest consult with E-CON to get support.
Small UPD:
E-con Systems engineers believe that the problem comes from the cv2.VideoCapture() function from OpenCV. Basically, it works too slowly to reliably capture high-resolution frames.
They suggest to bypass cv2.VideoCapture() as described in this post, rebuilding OpenCV with GStreamer, V4L, CUDA, OpenGL and other options and subsequently using C-based helper library to initialize the camera and read/display the frames.
However, this cmake script is outdated and doesn’t work for OpenCV 4.8.0. I made a few fixes to let it pass the build configuration step but the build fails repeatedly.
@ShaneCCC are there any tested solutions for SDK6.0+ for building OpenCV with GStreamer, V4L etc.? I haven’t found one yet but it would be extremely helpful for addressing this issue.
Do you confirm by gst-launch-1.0 v4l2src instead of cv2.VideoCapture()?
@ShaneCCC thank you for your idea, it is a very good point!
Indeed, I first ran a GStreamer pipeline displaying frames to a window:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=GRAY8,width=4200,height=3120,framerate=20/1 ! queue ! nvvidconv ! queue ! autovideosink
and then a pure “readout” pipeline without displaying (to exclude a rendering delay):
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=GRAY8,width=4200,height=3120,framerate=20/1 ! fakesink
and in both cases the freezing issue remained.
Although, I’m not sure about conclusions from this test, since GStreamer is yet another way to call V4L2 but still (as far as I understand) not a direct usage of V4L2.
That tell it doesn’t matter with the CV2.
You can also use v4l2-ctl --stream-mmap then consult with E-CON.
@ShaneCCC thank you! This test points to HW or drivers issue. I’ll pass this info to e-con and hope to write an update when the issue will be resolved.
I’ll leave my logs here in case any other people are or will be facing the same issue.
The camera should stream 4200 x 3120 px 8-bit greyscale frames at 20 FPS.
<<<<<<<<<<<<<<<<<<<<< 19.64 fps
<<<<<<<<< 13.56 fps, dropped buffers: 6
<<<<<<<<< 14.56 fps, dropped buffers: 1
<<<<<<< 13.79 fps, dropped buffers: 4
<<<<<<< 13.39 fps, dropped buffers: 4
<<<<<<<<<<<<<<<<< 14.44 fps, dropped buffers: 3
<<<<<<<<< 13.42 fps, dropped buffers: 6
<<<<<<< 13.74 fps, dropped buffers: 1
<<<<<<< 13.55 fps, dropped buffers: 5
<<<<<<<<<<<<<<<<<<< 14.17 fps, dropped buffers: 1
<<<<<<<<<<<<<< 14.12 fps, dropped buffers: 4
<<<<<<<<<<<<< 14.03 fps, dropped buffers: 4
< 13.65 fps, dropped buffers: 2
<<<<<<<<<<<<<<<<< 14.02 fps
<<<<<<< 12.63 fps, dropped buffers: 10
< 12.37 fps, dropped buffers: 2
<<<<<<< 12.36 fps, dropped buffers: 5
<<<< 12.22 fps, dropped buffers: 2
<<<<<<<<<<<<< 12.52 fps, dropped buffers: 3
<<< 12.20 fps, dropped buffers: 5
<<<<<<<<<<<<< 12.28 fps, dropped buffers: 4
< 12.10 fps, dropped buffers: 2
<<<<<<<<<<<<<<<<<< 12.41 fps, dropped buffers: 1
<<< 12.14 fps, dropped buffers: 5
<<<<<<<<<<<<<< 12.38 fps, dropped buffers: 2
Thanks to e-con Systems engineers, the issue is resolved. I would like to post the solution here, so other users who deal with issues in HR images streaming on Jetson Orin Nano SDK6.0-2 can fix it faster.
Frame Corruption Issue
The problem is described in the e-con Systems post Handling frame corruption in Linux for high-resolution imaging. In short, the number and size of UVC buffers (uvcvideo module) allocated in SDK6.x is not sufficient to handle 4200x3120 px, 8-bit, 20 FPS stream (2.1 Gbps total). This caused buffer overflows, frame corruption and subsequent camera freezing.
This is highly counterintuitive, because USB3.2 ports on Jetson Orin Nano have to handle 5+ Gbps, but their performance is limited on the system level. @ShaneCCC would it be possible to raise this issue internally and change it in the next SDK release?
Rebuilding the uvcvideo Module
On a practical note, to fix this issue, one needs to rebuild the uvcvideo module from source while changing UVC_URBS and UVC_MAX_PACKETS in uvcvideo.h.
Below you can find a step-by-step manual on how to do it in SDK6.2 / L4T36.4.3. This manual was kindly provided by e-con System engineers, slightly adapted and tested on our Orin Nano.
Step 1: Installation preparation
Make sure that L4T version is indeed 36.4.3:
jtop
Install necessary libraries:
sudo apt-get update
sudo apt-get install -y libssl-dev build-essential pkg-config libncurses-dev lbzip2
Prepare a build directory:
cd
mkdir uvc_driver
cd uvc_driver
mkdir build_dir
Step 2: Download source files and unzip them
For SDK6.2, the following link can be used:
wget "https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/sources/public_sources.tbz2"
For other SDK / L4T versions, please visit Jetson Linux page of the corresponding release and locate a link to Sources → Driver Package (BSP) Sources
Extract public sources:
tar -xf public_sources.tbz2
cd Linux_for_Tegra/source/
Extract Kernel source:
tar -xf kernel_src.tbz2
cd kernel/kernel-jammy-src/
Note: Here, depending on the version, the directory will be different.
Step 3: Update uvcvideo.h
sed -i -e '/#define DRIVER_VERSION/ s/"\(.*\)"/"\1-2"/' drivers/media/usb/uvc/uvcvideo.h
sed -i -e 's/#define UVC_URBS.*/#define UVC_URBS                1000/' drivers/media/usb/uvc/uvcvideo.h
sed -i -e 's/#define UVC_MAX_PACKETS.*/#define UVC_MAX_PACKETS         64/' drivers/media/usb/uvc/uvcvideo.h
Note: number of buffers is a total overkill (UVC_URBS 5 → 1000) but I haven’t invested my time to find optimal parameters.
Note: It is very useful for testing to change a driver version (1.1.1 → 1.1.1-2) to verify the installation
Step 4: Configure make and build a new UVC driver
make ARCH=arm64 O=~/uvc_driver/build_dir defconfig
make ARCH=arm64 O=~/uvc_driver/build_dir modules_prepare
make ARCH=arm64 O=~/uvc_driver/build_dir M=~/uvc_driver/Linux_for_Tegra/source/kernel/kernel-jammy-src/drivers/media/usb/uvc modules
Step 5: Driver replacement
Backup old uvcvideo module:
sudo mv -v /lib/modules/$(uname -r)/kernel/drivers/media/usb/uvc/uvcvideo.ko /lib/modules/$(uname -r)/kernel/drivers/media/usb/uvc/uvcvideo.ko.backup
Copy new uvcvideo module:
sudo cp drivers/media/usb/uvc/uvcvideo.ko /lib/modules/5.15.148-tegra/kernel/drivers/media/usb/uvc/
Apply changes and reboot:
sudo depmod -a
sudo reboot
Step 6: Verify driver update
modinfo /lib/modules/5.15.148-tegra/kernel/drivers/media/usb/uvc/uvcvideo.ko | grep version
Expected output:
       version:        1.1.1-2
After applying the fix, the issue with frame corruption/camera freezing was resolved:
v4l2-ctl --stream-mmap --stream-count=100
Suppose we apply the default UVC driver like the version with k5.15.
We may update it by JP7 but JP6.
