ECC Memory for Jetson AGX Orin 64GB
The module could be used as a small server I assume but with 64 GiB of RAM, how should this work without ECC?
The current Jetson AGX Orin are non DRAM ECC enabled.
Industrial Jetson AGX Orin will be available in 2023. It will be planning to have DRAM ECC support along with other safety features.
ok, good to know,. will they have the same form factor and connector?
Yes, same concept as the Xavier and Xavier industrial module.
