How do I check or test Memory ECC feature on AGX Orin Industrial
Continuing the discussion from AGX Orin Industrial ECC Information:
We try to check/test Memory ECC feature on AGX Orin Industrial on our baseboard.
Could you provide the command/method to check & test?
please refer to
Thanks for your infromation.
This verification only seems to injecting errors into memory locations, and then can read this from Linux command line.
However, we wou1d like to know if AGX ORIN Industrial module can correct the error successfully.
Can you proivde the test method to check this part?
Thank you!
Only SBE could be corrected and once the register count for SBE increases, it also means it got correction.
Hi @WayneWWW ,
Could I disable items in bootloader/tegra234-mb1-bct-dram-ecc-l4t.dtsi first and then enable them after flash and boot system?
Hi Wilson,
What thing do you want to disable here?
As I know we don’t enable ECC during flash and only happened after boot.
We found the following note in the documentation:
Note:
Activating ECC protection reduces the available memory for regular use to 7/8 of the total due to allocating additional memory for ECC data.
Also, on the Industrial version of the AGX Orin, the dmidecode output shows only 56GB of available memory:
Handle 0x000B, DMI type 16, 23 bytes
Physical Memory Array
    Use: System Memory
    Error Correction Type: Single-bit ECC
    Maximum Capacity: 56 GB
    Error Information Handle: Not Provided
    Number Of Devices: 1
In the bootloader configuration file bootloader/tegra234-mb1-bct-dram-ecc-l4t.dtsi, we observed the following parameters:
#include "tegra234-mb1-bct-dram-ecc.dtsi"
    misc {
        enable_dram_page_retirement = <1>;
        enable_dram_error_injection = <0>;
        enable_dram_staged_scrubbing = <0>;
We would like to ask:
  • If we set all these values to 0, does that effectively disable ECC?
  • If so, would the system memory be restored to the full 64GB?
  • Are these settings changeable after flashing and booting the OS, or must they be configured beforehand
Yes, it will
No, it won’t.
No, it has to be done before flash.
Yes, it will
A minor correction. SBE test may still work but DBE won’t.
So the available Memory Size of AGX Orin Industrial is always fixed at 56GB?
There are some preserved memory which is not related ECC but other usecase and we don’t suggest to configure them.
Got it, Thanks reply.
