NVIDIA gave us a workaround but we have some open questions that maybe forum moderators can chime in with.
You can inject error and keep reading the EMC status register to see if reported:
Disable SCR_CONFIG to allow access to the error injection carveout:
# Comment out (temporarily) the SCR_CONFIG variable in Linux_for_Tegra/p3701.conf.common
# SCR_CONFIG=“tegra234-mb2-bct-scr-p3701-0000.dts”;
Continue reading the status register for testing. The value of one of these status register will increment if a SBE or DBE is generated.
This is only for dev testing. You should not go to production with disabling the SCR config.
# emc-print-emc-ecc-status.sh
echo “EMC_ECC_STATUS_0 (EMC0) = $(sudo ./devmem2 0x02c70ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC1) = $(sudo ./devmem2 0x02c80ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC2) = $(sudo ./devmem2 0x02c90ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC3) = $(sudo ./devmem2 0x02ca0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC4) = $(sudo ./devmem2 0x02cb0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC5) = $(sudo ./devmem2 0x02cc0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC6) = $(sudo ./devmem2 0x02cd0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC7) = $(sudo ./devmem2 0x02ce0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC8) = $(sudo ./devmem2 0x01780ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC9) = $(sudo ./devmem2 0x01790ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC10) = $(sudo ./devmem2 0x017a0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC11) = $(sudo ./devmem2 0x017b0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC12) = $(sudo ./devmem2 0x017c0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC13) = $(sudo ./devmem2 0x017d0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC14) = $(sudo ./devmem2 0x017e0ac4 | awk ‘/Value at address/{print $6}’)”
echo “EMC_ECC_STATUS_0 (EMC15) = $(sudo ./devmem2 0x017f0ac4 | awk ‘/Value at address/{print $6}’)”
