Echo/Feedback Issue - Speaker Audio Being Captured by Microphone on Jetson Orin
I’m developing a Voice-to-Voice (V2V) interaction system for a robot using Jetson Orin, and I’m experiencing an audio feedback issue.
Hardware Setup:
  • Jetson Orin board
  • USB microphone
  • USB speaker
Problem:
Audio played through the USB speaker is being picked up by the USB microphone, causing echo and feedback in our voice interaction pipeline. This creates a loop where the robot’s speech output interferes with voice input processing.
Current Impact:
  • Unable to implement real-time voice conversations
  • Speech recognition fails due to feedback interference
  • System cannot distinguish between user speech and robot’s own audio output
Questions:
  1. Are there recommended audio configurations or ALSA settings for Jetson Orin to minimize acoustic feedback?
  2. Should I implement software-based Acoustic Echo Cancellation (AEC), or are there hardware-level solutions?
  3. Are there best practices for USB audio device setup on Jetson platforms for bidirectional voice applications?
Any guidance on solving this echo/feedback issue would be greatly appreciated. Thank you!
To address the audio feedback issue in your Voice-to-Voice (V2V) interaction system using Jetson Orin, I’ll provide a comprehensive answer covering recommended audio configurations, ALSA settings, software-based Acoustic Echo Cancellation (AEC), hardware-level solutions, and best practices for USB audio device setup.
Recommended Audio Configurations and ALSA Settings:
  1. Audio Device Selection: Ensure that the USB microphone and speaker are properly configured and recognized by the Jetson Orin system. You can use the arecord and aplay commands to test the audio devices.
  2. ALSA Configuration: Edit the ALSA configuration file (/etc/asound.conf or ~/.asoundrc) to optimize the audio settings for your application. You can add the following lines to the configuration file to reduce echo and feedback:
pcm.!default {
  type asym
  playback.pcm "playback"
  capture.pcm "capture"
pcm.playback {
  type plug
  slave.pcm "hw:1,0"
pcm.capture {
  type plug
  slave.pcm "hw:2,0"
Replace hw:1,0 and hw:2,0 with the actual device numbers for your USB speaker and microphone, respectively.
  1. Audio Gain Control: Adjust the audio gain levels for the microphone and speaker to minimize echo and feedback. You can use the amixer command to set the gain levels.
Software-based Acoustic Echo Cancellation (AEC):
  1. AEC Algorithms: Implement a software-based AEC algorithm, such as the Speex AEC or the WebRTC AEC, to reduce echo and feedback in your voice interaction pipeline. These algorithms can be integrated into your application using libraries like libspeex or webrtc.
  2. AEC Configuration: Configure the AEC algorithm to optimize its performance for your specific use case. This may involve adjusting parameters like the echo tail length, the filter length, and the adaptation rate.
Hardware-level Solutions:
  1. Acoustic Echo Cancellation (AEC) Hardware: Consider using a dedicated AEC hardware module, such as the Texas Instruments AEC module, to reduce echo and feedback. These modules can be integrated into your system design to provide a hardware-based AEC solution.
  2. Audio Isolation: Implement audio isolation techniques, such as using a separate audio codec for the microphone and speaker, to reduce electrical coupling and minimize echo and feedback.
Best Practices for USB Audio Device Setup:
  1. USB Audio Device Selection: Choose USB audio devices that are compatible with the Jetson Orin platform and optimized for bidirectional voice applications.
  2. USB Audio Device Configuration: Configure the USB audio devices to use the correct audio formats, sample rates, and buffer sizes to minimize echo and feedback.
  3. Audio Device Synchronization: Ensure that the audio devices are synchronized to minimize latency and echo. You can use the jack command to synchronize the audio devices.
Additional Guidance:
  1. Audio Signal Processing: Implement audio signal processing techniques, such as noise reduction and echo suppression, to further improve the audio quality and reduce echo and feedback.
  2. System Tuning: Perform system tuning to optimize the audio settings and minimize echo and feedback. This may involve adjusting parameters like the audio gain levels, the AEC algorithm configuration, and the audio device settings.
  3. Testing and Validation: Perform thorough testing and validation to ensure that the audio feedback issue is resolved and the voice interaction pipeline is functioning correctly.
By following these guidelines and implementing the recommended audio configurations, ALSA settings, software-based AEC, hardware-level solutions, and best practices for USB audio device setup, you should be able to minimize acoustic feedback and achieve a high-quality voice interaction experience for your robot using Jetson Orin.
