Hello.I am trying to run PCB defect detection programm on my jetson nano.I need deepstream to run this programm, so i am going to use the deepstream docker container.
I have a question:
Is it possible to edit config file “Config_infer_primary_yoloV5.txt”, which is located in the docker container ? If so, how can i do that ?
Thanks for your reply.I use nvcr.io/nvidia/deepstream-l4t:6.0.1-samples container. Unfortunatelly, i i still can’t get how to put Config_infer_primary_yoloV5.txt (with the necessary changes in it) in the docker container.It is not part of the container, so i should download this txt file and put it in the container structure?If so, how can i do that ?
Thanks for the fast reply.But unfortunatelly, i still cant get how to edit the file.
There is no any commands about editing in this instruction, so i cant understand how to start edit the Config_infer_primary_yoloV5.txt file.
4. Edit the config_infer_primary.txt file according to your model (example for YOLOv4)
