I updated to RHEL 5.10 and I’m trying to build ofed modules against the latest 2.6.18-371.1.2.el5 kernel.
./mlnx_add_kernel_support.sh -k 2.6.18-371.1.2.el5 -m /mnt/ofed --make-tgz
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
ofed-scripts
kernel-ib
kernel-ib-devel
Uninstalling the previous version of OFED
Build ofed-scripts RPM
Running rpmbuild --rebuild --define ‘_topdir /tmp/mlnx_iso.14232/OFED_topdir’ --define ‘dist %{nil}’ --target x86_64 --define ‘_prefix /usr’ --define ‘_exec_prefix /usr’ --define ‘_sysconfdir /etc’ --define ‘_usr /usr’ /tmp/mlnx_iso.14232/MLNX_OFED_SRC-1.5.3-4.0.42/SRPMS/ofed-scripts-1.5.3-OFED.1.5.3.4.0.42.src.rpm
Install ofed-scripts RPM:
Running rpm -iv /tmp/mlnx_iso.14232/MLNX_OFED_SRC-1.5.3-4.0.42/RPMS/redhat-release-5Server-5.10.0.4/x86_64/ofed-scripts-1.5.3-OFED.1.5.3.4.0.42.x86_64.rpm
Build ofa_kernel RPM
Running rpmbuild --rebuild --define ‘_topdir /tmp/mlnx_iso.14232/OFED_topdir’ --nodeps --define ‘_dist .rhel5u10’ --define ‘configure_options --with-core-mod --with-user_mad-mod --with-user_access-mod --with-addr_trans-mod --with-mthca-mod --with-mlx4-mod --with-nes-mod --with-qib-mod --with-ipoib-mod --with-sdp-mod --with-srp-mod’ --define ‘build_kernel_ib 1’ --define ‘build_kernel_ib_devel 1’ --define ‘KVERSION 2.6.18-371.1.2.el5’ --define ‘K_SRC /lib/modules/2.6.18-371.1.2.el5/build/’ --define ‘network_dir /etc/sysconfig/network-scripts’ --define ‘_prefix /usr’ --define ‘__arch_install_post %{nil}’ /tmp/mlnx_iso.14232/MLNX_OFED_SRC-1.5.3-4.0.42/SRPMS/ofa_kernel-1.5.3-OFED.1.5.3.4.0.42.g3cb72fe.src.rpm
Failed to build ofa_kernel RPM
See /tmp/OFED.14279.logs/ofa_kernel.rpmbuild.log
And the error is:
In file included from include/linux/inetdevice.h:7,
from /tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/kernel_addons/backport/2.6.18-EL5.7/include/linux/inetdevice.h:4,
from /tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/drivers/infiniband/core/addr.c:37:
/tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/kernel_addons/backport/2.6.18-EL5.7/include/linux/netdevice.h:25: error: conflicting types for ‘netif_is_bond_slave’
include/linux/netdevice.h:884: error: previous definition of ‘netif_is_bond_slave’ was here
make[4]: *** [/tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/drivers/infiniband/core/addr.o] Error 1
make[3]: *** [/tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/drivers/infiniband/core] Error 2
make[2]: *** [/tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3/drivers/infiniband] Error 2
make[1]: *** [module/tmp/mlnx_iso.7969/OFED_topdir/BUILD/ofa_kernel-1.5.3] Error 2
make[1]: Leaving directory `/usr/src/kernels/2.6.18-371.1.2.el5-x86_64’
make: *** [kernel] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.35818 (%build)
What I’m doing wrong?
Regards,
Tommi
