bug report: https://pastebin.com/pA6qYnhP
I’ve got 2 2080ti’s on the way, I can only imagine the power draw if this bug applies to them too!
Nvidia-smi doesn’t display the power draw of your gpu, how did you measure it? Since it stays at 27°C I find it hard to believe it’s really pulling 35 Watts.
nvidia-smi stats gives output:
0, pwrDraw , 1546024020323043, 35
0, temp , 1546024020355288, 27
After a fresh boot, if I run a load for a bit, when back at P8 it will idle at 19C. 27C is VERY high for this card in this system. During full load (100% core and 100% memory util) for 10min it will only hit ~40C with fan only at 35%…during full load pwrDraw shows 68w.
‘stats’ was an experimental option, don’t rely on it outputting true values.
Ok, but:
These tell me it is using more power.
Maybe start with checking for a newer bios, problems after suspend/resume are most often related to that.
