siyzz
1
model: colorful 3060ti adoc
Set the maximum power to 140w but the actual power is more tha 200w
# nvidia-smi -i 1
Thu Jun 30 09:27:03 2022
| NVIDIA-SMI 510.60.02 Driver Version: 510.60.02 CUDA Version: 11.6 |
| | | MIG M. |
| 1 NVIDIA GeForce ... On | 00000000:04:00.0 Off | N/A |
|100% 80C P2 237W / 140W | 5175MiB / 8192MiB | 100% Default |
| | | N/A |
What’s the power display while idle?
siyzz
4
thanks, just 38w when the card is idle.
# nvidia-smi -i 1
Fri Jul 1 08:31:37 2022
| | | MIG M. |
| 49% 46C P3 38W / 140W | 0MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Looks like you’re running headless, please setup nvidia-persistenced to start on boot and check if that resolves the issue.
siyzz
6
I had set persistence mode with ‘nvidia-smi -pm 1’.
# nvidia-smi -i 1 -q
==============NVSMI LOG==============
Timestamp : Sun Jul 3 11:46:17 2022
Driver Version : 510.60.02
CUDA Version : 11.6
Attached GPUs : 2
GPU 00000000:04:00.0
Product Name : NVIDIA GeForce RTX 3060 Ti
Product Brand : GeForce
Product Architecture : Ampere
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-8d3b43ec-a4fd-f07a-a264-f4a9de50aef8
Minor Number : 1
VBIOS Version : 94.04.46.40.D9
MultiGPU Board : No
Board ID : 0x400
GPU Part Number : N/A
Module ID : 0
siyzz
7
I have 2 cards,the another one is prospective.
# nvidia-smi
Sun Jul 3 11:52:18 2022
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:03:00.0 Off | N/A |
| 79% 67C P2 139W / 140W | 5183MiB / 8192MiB | 100% Default |
| | | N/A |
|100% 81C P2 232W / 140W | 5183MiB / 8192MiB | 100% Default |
| | | N/A |
siyzz
8
Has anyone encountered a similar problem?
siyzz
9
The problem is solved.
Flashed another BIOS with Nvflash.
Thanks @generix
system
Closed
10
