I have a 10in touchscreen ELO monitor I am trying to use with the standard Nano board. When booting the board with this monitor hooked up the board looks to partially boot before something happens causing the board to reboot. Attached is what I see on the screen before the restart. The board works fine with a couple other displays, so the issue looks specific to this monitor. What would be the best place to start to try and troubleshoot this issue?
You’d probably want to get a serial console boot log. Serial console functions even in the bootloader stages prior to Linux ever starting, and has almost no requirements. Basically your PC would record the boot logs for you. See:
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
Looking through the console boot log it looks like a software reset it triggered right as the kernel starts to load. How could this happen from an HDMI connection? I’ll attach the full log of a couple restarts. Any idea on settings to adjust to work around this issue?
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4428) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue
Oct 27 21:02:37 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[0000.157] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.163] Processing in cold boot mode Bootloader 2
[0000.167] A02 Bootrom Patch rev = 1023
[0000.171] Power-up reason: software reset
[0000.175] No Battery Present
[0000.177] pmic max77620 reset reason
[0000.181] pmic max77620 NVERC : 0x0
[0000.184] RamCode = 0
[0000.186] Platform has DDR4 type RAM
[0000.190] max77620 disabling SD1 Remote Sense
[0000.194] Setting DDR voltage to 1125mv
[0000.198] Serial Number of Pmic Max77663: 0x2f19f0
[0000.205] Entering ramdump check
[0000.208] Get RamDumpCarveOut = 0x0
[0000.212] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.217] Last reboot was clean, booting normally!
[0000.221] Sdram initialization is successful
boot_error_log.txt (66.4 KB)
I had missed this error message when I try to connect the display after the Nano has already booted.
[ 108.011524] tegra-dvfs: rate 768000000 too high for dvfs on disp1
[ 108.011527] tegradc tegradc.0: hdmi: set dc parent failed
[ 108.016615] tegradc tegradc.0: pclk out of range!
[ 108.016618] tegradc tegradc.0: tegra_dc_init: tegra_dc_program_mode failed
[ 108.016632] tegradc tegradc.0: _tegra_dc_controller_enable: tegra_dc_init failed
[ 108.047231] tegra-dvfs: rate 768000000 too high for dvfs on disp1
[ 108.047234] tegradc tegradc.0: hdmi: set dc parent failed
[ 108.052985] tegradc tegradc.0: pclk out of range!
[ 108.052988] tegradc tegradc.0: tegra_dc_init: tegra_dc_program_mode failed
[ 108.053002] tegradc tegradc.0: _tegra_dc_controller_enable: tegra_dc_init failed
I do not see the above in the “boot_error_log.txt”, but this would simply imply the monitor is using values the GPU cannot achieve.
I will suggest that if you modify the Xorg config file to tell the driver to verbosely comment on all modes, then it will tell use useful details about what might actually be out of range. In file “/etc/X11/xorg.conf”, you will see a Section "Device". Within this you’ll add Option "ModeDebug":
Section "Device"
Option "ModeDebug"
Then reboot. The log file “/var/log/Xorg.0.log” (or in some cases “Xorg.1.log”) will then tell us details about each mode from the EDID. Save a copy of that log (you might want to rename the copy with a filename extension of “.txt”), and attach a copy to the forum. Then we’ll know what modes might or might not be used.
Do note that the drivers of a Jetson have more restrictions than those of a desktop PC. For example, extension modes and interlaced will always be rejected.
Attached is the full log file. It seems to select a mode=“Null”. What is the proper way to set a default mode for it to try?
[ 103.764] (II) NVIDIA(GPU-0): --- Modes in ModePool for ELO ET1093L (DFP-0) ---
[ 103.764] (II) NVIDIA(GPU-0): "nvidia-auto-select" : 1280 x 800 @ 60.0 Hz (from: EDID, Detailed)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1200" : 1920 x 1200 @ 59.9 Hz (from: EDID)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1200_60" : 1920 x 1200 @ 59.9 Hz (from: EDID)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1080" : 1920 x 1080 @ 60.0 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1080_60" : 1920 x 1080 @ 60.0 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1080_60_0" : 1920 x 1080 @ 60.0 Hz (from: EDID)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1080_60_1" : 1920 x 1080 @ 59.9 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1920x1080_50" : 1920 x 1080 @ 50.0 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1280x800" : 1280 x 800 @ 60.0 Hz (from: EDID, Detailed)
[ 103.764] (II) NVIDIA(GPU-0): "1280x800_60" : 1280 x 800 @ 60.0 Hz (from: EDID, Detailed)
[ 103.764] (II) NVIDIA(GPU-0): "1280x720" : 1280 x 720 @ 60.0 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1280x720_60" : 1280 x 720 @ 60.0 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1280x720_60_0" : 1280 x 720 @ 59.9 Hz (from: EDID, CEA)
[ 103.764] (II) NVIDIA(GPU-0): "1024x768" : 1024 x 768 @ 60.0 Hz (from: EDID)
[ 103.764] (II) NVIDIA(GPU-0): "1024x768_60" : 1024 x 768 @ 60.0 Hz (from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): "800x600" : 800 x 600 @ 60.3 Hz (from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): "800x600_60" : 800 x 600 @ 60.3 Hz (from: EDID)
(from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): "800x500" : 800 x 500 @ 59.5 Hz (from: EDID, Detailed)
[ 103.765] (II) NVIDIA(GPU-0): "800x500_59" : 800 x 500 @ 59.5 Hz (from: EDID, Detailed)
[ 103.765] (II) NVIDIA(GPU-0): "720x576" : 720 x 576 @ 50.0 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "720x576_50" : 720 x 576 @ 50.0 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "720x480" : 720 x 480 @ 59.9 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "720x480_60" : 720 x 480 @ 59.9 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "720x400" : 720 x 400 @ 70.0 Hz (from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): "720x400_70" : 720 x 400 @ 70.0 Hz (from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): "640x480" : 640 x 480 @ 59.9 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "640x480_60" : 640 x 480 @ 59.9 Hz (from: EDID, CEA)
[ 103.765] (II) NVIDIA(GPU-0): "640x480_60_0" : 640 x 480 @ 59.9 Hz (from: EDID)
[ 103.765] (II) NVIDIA(GPU-0): --- End of ModePool for ELO ET1093L (DFP-0): ---
[ 103.767] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): connected
[ 103.767] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): External TMDS
[ 103.767] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0) Name Aliases:
[ 103.767] (--) NVIDIA(GPU-0): DFP
[ 103.767] (--) NVIDIA(GPU-0): DFP-0
[ 103.767] (--) NVIDIA(GPU-0): DPY-0
[ 103.767] (--) NVIDIA(GPU-0): HDMI-0
[ 103.767] (--) NVIDIA(GPU-0): DPY-EDID-d5d6b26f-64f9-73e5-f6fd-87fe7f41ac25
[ 103.775] (II) NVIDIA(0): Setting mode "NULL"
[ 103.782] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): connected
[ 103.782] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): External TMDS
[ 103.782] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0) Name Aliases:
[ 103.782] (--) NVIDIA(GPU-0): DFP
[ 103.782] (--) NVIDIA(GPU-0): DFP-0
[ 103.782] (--) NVIDIA(GPU-0): DPY-0
[ 103.782] (--) NVIDIA(GPU-0): HDMI-0
[ 103.782] (--) NVIDIA(GPU-0): DPY-EDID-d5d6b26f-64f9-73e5-f6fd-87fe7f41ac25
+0+0 {AllowGSYNC=Off, ViewPortIn=1280x800, ViewPortOut=1280x800+0+0}"
[ 103.962] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): connected
[ 103.962] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): External TMDS
[ 103.962] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0) Name Aliases:
[ 103.962] (--) NVIDIA(GPU-0): DFP
[ 103.962] (--) NVIDIA(GPU-0): DFP-0
[ 103.962] (--) NVIDIA(GPU-0): DPY-0
[ 103.962] (--) NVIDIA(GPU-0): HDMI-0
[ 103.963] (--) NVIDIA(GPU-0): DPY-EDID-d5d6b26f-64f9-73e5-f6fd-87fe7f41ac25
[ 103.963] (--) NVIDIA(GPU-0): HDMI-0
[ 107.404] (--) NVIDIA(GPU-0): ELO ET1093L (DFP-0): connected
Xorg_Log.txt (228.0 KB)
It is interesting that you have a lot of valid modes. EDID is obviously working, and the monitor itself is compatible. However, in the log I did not see any pick of horizontal or vertical scan rates being picked, and I am only guessing, but this seems to be why the monitor is not working…lack of using valid scan rates from valid modes in the mode pool.
HDMI is “hot plug”, so as an experiment, if you continue to monitor “tail -f /var/log/Xorg.0.log”, and then unplug and replug the monitor, what shows up as a result of the plug-in (you can ignore log text from unplug, only the replug will matter).
Also, try something similar while monitoring logs…boot with a known working monitor, unplug that monitor, and then plug in the non-working monitor.
I’m hoping that a hot plug from an up and running system will get past something which is failing when always connected.
If you have serial console or ssh login, and you can leave the monitor running (or attempting to run) in GUI mode, then you could use your ssh or serial console login for manual mode setting attempts. In that terminal you would run this command first:
export DISPLAY=:0
Then (with DISPLAY exported) you could use “xrandr” to display what modes should be possible. Post what you see. We can then try manual mode setting from the non-GUI terminal.
I have gone through a lot of the modes that come up, but they are all showing up with an error. Is the 768000000 rate the clock setting it is trying to use? This does not seems to change at the different refresh rates. Is there a way to manually adjust this down to test?
rustuser@rustuser-desktop:~$ xrandr
Screen 0: minimum 8 x 8, current 800 x 600, maximum 16384 x 16384
HDMI-0 connected primary 800x600+0+0 (normal left inverted right x axis y axis) 220mm x 140mm
1280x800 60.00 +
1920x1200 59.89
1920x1080 60.00 59.95 50.00
1280x720 60.00 59.94
1024x768 60.01
800x600 60.32* 56.25
800x500 59.50
720x576 50.00
720x480 59.94
720x400 70.04
640x480 59.94 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
1280x720_50.00 (0x1cc) 60.500MHz -HSync +VSync
h: width 1280 start 1328 end 1456 total 1632 skew 0 clock 37.07KHz
v: height 720 start 723 end 728 total 744 clock 49.83Hz 4
[ 1961.236351] tegra-dvfs: rate 768000000 too high for dvfs on disp1--rate 59.94
[ 1961.236354] tegradc tegradc.0: hdmi: set dc parent failed
[ 1961.241055] tegradc tegradc.0: pclk out of range!
[ 1961.241059] tegradc tegradc.0: tegra_dc_init: tegra_dc_program_mode failed
[ 1961.241071] tegradc tegradc.0: _tegra_dc_controller_enable: tegra_dc_init failed
[ 1961.272567] tegra-dvfs: rate 768000000 too high for dvfs on disp1
[ 1961.272582] tegradc tegradc.0: hdmi: set dc parent failed
[ 1961.278928] tegradc tegradc.0: pclk out of range!
[ 1961.278931] tegradc tegradc.0: tegra_dc_init: tegra_dc_program_mode failed
[ 1961.278942] tegradc tegradc.0: _tegra_dc_controller_enable: tegra_dc_init failed
Screen 0: minimum 8 x 8, current 1280 x 720, maximum 16384 x 16384
HDMI-0 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 220mm x 140mm
1280x800 60.00 +
1920x1200 59.89
1280x720 60.00 59.94*
1024x768 60.01
800x600 60.32 56.25
800x500 59.50
720x576 50.00
720x480 59.94
720x400 70.04
640x480 59.94 59.94
The DVFS table is the Digital Voltage and Frequency Scale, and sets minimums and maximums for certain clocks and regulators. If the pixel clock (pclk) is out of range of either the monitor or the driver/GPU, then the mode is refused.
I would be very surprised if the monitor is too fast for the GPU, but I would also surprised if frequencies are so slow the pixel clock rate is out of bounds.
Would someone from NVIDIA be able to suggest a way to research the reason why there are many accepted modes in the mode pool, and yet the pixel clock is out of range? It seems odd that the pixel clock would not be considered when listing accepted modes.
I think there is something wrong with this pclk… It is 768Mhz. Even a common RGB 4k@60 monitor requires only 594Mhz…
How is it possible a mode 1280x800@60 requires such pclk?
Could you dump
- The edid.
sudo -s
root@tegra-ubuntu:/sys/kernel/debug/tegradc.0# cat edid
Please note that there might be tegradc.0/1/2. Just pick the one that has your HDMI edid.
- The mode data
root@tegra-ubuntu:/sys/kernel/debug/tegradc.0# cat mode
We need to check the detail of this mode and see why it requires such large pclk.
Any feedback here?
The device I was testing on had to go into service with a different brand of monitor we were able to get working. The different monitors would pick up these modes with problems at first, but after a fresh image they worked fine. I have not got the time to setup a new device and hook up the faulty ELO monitor.
Ok, please report the status when you are available.
