Enable TPM infineon
Hi ,
i follow the topic:
without success.
Why the pinmux on the topic 266719 is not this:
devmem2 0x0243d028 w 0x00000444
devmem2 0x0243d018 w 0x00000444
devmem2 0x0243d040 w 0x00000444
devmem2 0x0243d008 w 0x00000008
devmem2 0x0243d038 w 0x00000448
to enable SPI1 ? Furthermore i’ll set this on runtime and then load the follow module :
tpm_tis_spi tpm_tis_core tpm_tis but the driver replies with:
tpm_tis_spi: probe of spi0.0 failed with error -110.
thanks
Best regards
VP
Hi vpellino,
Are you working on IGX developer kit or board kit?
Please share the full dmesg/device tree and also the result of the following command on your board.
$ ls -l /dev/spi*
$ cat /proc/device-tree/bus@0/spi@3210000/status
$ zcat /proc/config.gz |grep -E "CONFIG_TCG_TIS_CORE|CONFIG_TCG_TIS_SPI"
Hi Kevin,
thanks for reply.
okay
for spi device i see in the kernel log :
[ 3.153719] spi-tegra114 3210000.spi: Adding to iommu group 1
ls -l /dev/spi*
ls: cannot access ‘/dev/spi*’: No such file or directory
in my configuration there isn’t the file /proc/config.gz but i already compile the features with modules mode for debugging, so i have the tpm_tis_spi.ko, tpm_tis.ko and tpm_tis_core.ko kernel modules.
VP
So, are you using IGX developer kit or board kit?
Please try to run the following command instead.
$ grep CONFIG_TCG_TIS /boot/config-$(uname -r)
Do you also update the device tree?
Hi Kevin,
CONFIG_TCG_TIS_CORE=y
CONFIG_TCG_TIS=y
CONFIG_TCG_TIS_SPI=m
CONFIG_TCG_TIS_SPI_CR50=y
CONFIG_TCG_TIS_SYNQUACER=m
CONFIG_TCG_TIS_I2C_CR50=m
CONFIG_TCG_TIS_I2C_ATMEL=m
CONFIG_TCG_TIS_I2C_INFINEON=m
CONFIG_TCG_TIS_I2C_NUVOTON=m
CONFIG_TCG_TIS_ST33ZP24=m
CONFIG_TCG_TIS_ST33ZP24_I2C=m
CONFIG_TCG_TIS_ST33ZP24_SPI=m
Yes i have update the device tree but i have a question about reset pin :
reset-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(A, 2) GPIO_ACTIVE_LOW>;
i checked on tpm pins strip configured with gpio mode the A,2 but is not connected on pin strip. Is it a problem?
PA.02
echo 350 > export
devmem2 0x02432030 w 1
echo out > PA.02/direction
echo 1 > PA.02/value
echo 0> PA.02/value
after this i didn’t see the gpio movementi on the j43 connector.
VP
We just checked the schematic that we use SYS_RESET_N as the reset gpio for TPM so that TPM should get reset during boot up.
I want to confirm that if you haveTPM module on the IGX devkit.
(i.e. do you connect TPM module on the J43?)
Hi Kevin,
so the device-tree configuration for TPM is:
spi@3210000 {
		status = "okay";
// I think the first chip select is based on @0 in the device name
//		cs-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 6) GPIO_ACTIVE_LOW>;
		sbl9670@0 {
			compatible = "infineon,slb9670";
			reg = <0x0>;
			spi-max-frequency = <32000000>;
			controller-data {
				nvidia,variable-length-transfer;
				nvidia,rx-clk-tap-delay = <0x31>;
Yes i have TPM module ( Gigabyte TPM GC-TPM2.0 SPI 2.0 ) on J43.
Thank You
VP
So, it seems the different model as slb9670…
Please request your vendor for the porting guide for this module.
Hi kevin,
the module is this: https://www.gigabyte.com/Motherboard/GC-TPM20-SPI-20#ov
it is slb9670 infineon chip.
VP
You may still need to configure CS gpio here.
Plea try if the following device tree working in your case.
	spi@3210000 {
		status = "okay";
		sbl9670@0 {
			spi-max-frequency = <0x1e84800>;
			reg = <0x1>;
			controller-data {
Please also confirm that the pinmux for this SPI interface has benn configured correctly for SPI usage.
