Encoding interlaced video
Continuing the discussion from Decoding of interlaced H264 bistreams: interlaced output:
If the situation did not change, and if it applies to our platform (Xavier NX), I understand that we cannot get top/bottom frames out of the decoder, only progressive. Is that still true?
What is the situation on the encoder side? Can the encoder ingress top/bottom frame and encode them in a way that the decoder can understand, preferably using the h26x standard supported flags?
I no, is that a limitation of the hardware, closed source libraries? Or is this possible to use the lowest level of the multimedia API and get it work?
We currently use Xavier NX with the latest BSP4 libraries (R32.7.6)
In decoding, if the h264/h265 stream is interlaced compressed, it will be de-interlaced automatically to have progressive output. In encoding, encoding interlaced frames is not supported. If you would like to encode interlaced frames, please look for software encoder.
