Does omxh264enc supports interlace encoding with Tegra X1?
Hi ACervantes,
It is not supported. Another discussion thread:
https://devtalk.nvidia.com/default/topic/976602/jetson-tx1/interlaced-encoding-mode-on-tegra-x1/post/5055689/#5055689
Hi DaneLLL,
Thanks for your fast response. Do you know if this is a hardware limitation, a codec limitation or just that the gstreamer element doesn’t expose the capabilities to encode interlace?
thanks,
-David
Hi DavidSoto,
We don’t have the full SW implementation for interlacing encoding.
Understood. Thank you DaneLLL
