Does omxh264dec supports interlace decoding with Tegra X2?
I have a H264 file which was encoded by interlace。Does omxh264dec can decode this H264 file?
Interlaced H264 stream can be decoded and de-interlaced into progressive frames. Please try nvv4l2decoder plugin.
Thank you very much, and the R28.2 multimedia can also support it?
We suggest use r28.3 or later release. On r28.2, there is a known issue:
OK,Thank you. Can the TX1 also support interlaced video?
I still can not decode my interlace video file, use cmd “./video_decode H264 --disable-rendering -o deint_test.yuv deint_test.264”.
@DaneLLL
The file is at:
提取码是:nkha
链接: 百度网盘 请输入提取码 提取码: nkha 复制这段内容后打开百度网盘手机App,操作更方便哦
We cannot access the link. You can try to attach it here.
And suggest you try JP4.4.1(r32.4.4).
I will make a try, Thank you!But I want to know if the TX1 also support interlace video?
Replied in
