I have tried absolutely everything. When I first flashed the OS, it worked fine, then a few days later I get this error. I tried everything to fix it and followed a few threads here but I had no luck.
I just want to see the feed from my camera so i run these commands:
sensor_id=0 # 0 for CAM0 and 1 for CAM1 ports
Framerate=30
gst-launch-1.0 nvarguscamerasrc sensor_id=$sensor_id ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$Framerate/1,format=NV12" ! nvvidconv flip-method=0 ! "video/x-raw,width=960,height=720" ! nvvidconv ! nvegltransform ! nveglglessink -e
I get this error: WARNING: erroneous pipeline: no element “nvarguscamerasrc”
Based on the provided context, it appears that you are experiencing issues with the nvarguscamerasrc element on your Jetson Orin Nano device. The error message “WARNING: erroneous pipeline: no element nvarguscamerasrc” suggests that the nvarguscamerasrc element is not available or not properly configured.
To troubleshoot this issue, let’s compare your situation with similar issues reported by other users.
Similar issues:
“Nvarguscamerasrc not working (URGENT)” ( Jetson Orin Nano camera ) - This thread discusses a similar issue with nvarguscamerasrc not working on Jetson Orin Nano. The solution involves checking the device tree and ensuring that the camera sensor is properly configured.
“Gst-nvarguscamera fails on Jetpack 6.0” ( Jetson Orin NX camera ) - This thread reports a similar issue with gst-nvarguscamera failing on Jetpack 6.0. The solution involves updating the device tree and ensuring that the camera sensor is properly configured.
Device tree configuration:
The device tree configuration is crucial for camera functionality on Jetson devices. Ensure that your device tree is properly configured for your camera sensor. You can refer to the “DeviceTree.txt” file provided in the “Capturing Image from custom sensor fails with 4-csi lanes” thread for an example of a properly configured device tree.
Camera sensor configuration:
Ensure that your camera sensor is properly configured and connected to the Jetson Orin Nano device. You can refer to the “IMX219 not detected on JetPack 6 (Error -121)” thread for troubleshooting steps specific to the IMX219 camera sensor.
Jetpack version:
Ensure that you are running the latest Jetpack version (6.2) on your Jetson Orin Nano device. You can refer to the “Jetpack 6.2” release notes for information on camera-related fixes and improvements.
To resolve the issue, you can try the following steps:
Verify that your device tree is properly configured for your camera sensor.
Ensure that your camera sensor is properly connected and configured.
Update to the latest Jetpack version (6.2) if you haven’t already.
Refer to the “Nvarguscamerasrc not working (URGENT)” and “Gst-nvarguscamera fails on Jetpack 6.0” threads for additional troubleshooting steps.
If none of these steps resolve the issue, please provide more details about your setup, including the camera sensor model, device tree configuration, and any error messages you encounter.
Why is the device tree related here? I am a beginner so I am a bit confused. It used to work fine and I could see a feed. But now I get this error everywhere
Hello, I have an IMX519. I followed the wiki here for the drivers and it worked perfectly on a new image but now I keep getting this nvarguscamerasrc error and I cannot do anything.
What would be the process of getting both cam0 and cam1 also working, thats also another thing i am struggling with
It is, it shows up. I reflashed the OS and its working fine I am just scared that this error happens again and my only option is to reflash as it has happened twice already.
Hey! thanks for the speedy replies. I am a beginner so I am a bit confused. The device tree is stored under /boot/extlinux/extlinux.conf? and I should make a copy of that incase the error happens again?
