Friends, I have trouble installing the pgi 6.1 on ubuntu 7.10 AMD 64 bits. When you type the command . /Install, appears this error: ERROR: arch not found (PATH = $PATH)
What should I do.
Thankful
Puffy
My email: puffy78@gmail.com
What should I do.
Thankful
Puffy
Hi Puffy,
Please change “arch” to “uname -m” in install script. Please let us know if this helps.
Thanks,
Hongyon
It worked, more now appeared another error: ERROR: unknown glibc version (2.6.1).
Test: 364: / usr/lib/gcc/x86_64-linux-gnu/3.4.6 /: unexpected operator
What can be?
Grateful
6.1 is an older release and not yet supported newer glibc. I would recommend you install our latest release 7.1-2 instead.
If you want to install 6.1 on new OS, please contact trs@pgroup.com on how to proceed.
Hongyon
