I am trying to compile a ptx file with -arch-sm_20 (since i need the ld.global.cg instruction) but I get the “SM version assumed by .target is higher than sm version specified”. I am using the GPGPU-Sim pre-installed virtual machine (ubuntu 14.04, CUDA 4.2). Any help will be appreciated. Thank you.
Related topics
| Error compiling ptx file : "SM version assumed by .target is higher than SM version assumed" | 3 | 2358 | November 24, 2016 | |
| Does the driver JIT support PTX 1.3/2.0 binaries on older cards? If so, how? | 5 | 2851 | April 24, 2010 | |
| Cuda 3.0 & sm_20: ptxas fatal : Value 'sm_20' is not defined for option 'gpu-name& | 0 | 7135 | April 6, 2010 | |
| PTX .version 3.1 does not support .target sm_50 | 2 | 1400 | June 14, 2022 | |
| Bug on Windows | 5 | 2205 | August 9, 2011 | |
| question Regarding ptxas info and some weird problem | 7 | 957 | November 23, 2010 | |
| Quick Question : how to change the default SM architecture in the Optix samples ? | 5 | 4895 | June 14, 2022 | |
| Problems with Toolkit 3 Cannot compile sdk examples on VS2008 | 3 | 6405 | March 25, 2010 | |
| Kernel 2x slower when compiling with sm12 and above | 3 | 2414 | May 24, 2012 | |
| How to compile with PTX ISA v2.3 support? | 4 | 1736 | April 22, 2013 |
