Hey can anyone help with the following error which pops up when I try to compile a simple mpi code using PGI visual fortran
Error while connecting to host. No connection could be made because the target machine actively refused it. <10061>
Connect on sock <host=…,port=…> failed, exhaused all end points
Unable to connect to ‘…:8678’
sock error: Error = -1
I have the admin rights so I don’t know whats the issue. Please help
Are you seeing this at compile time or are you running built code?
If at compile time, then perhaps it is a licensing problem, and you should email license@pgroup.com and we can work through it. Could be a firewall or a configuration problem.
If this is happening when you run a built program, send a PVF solution that
demonstrates the failure to trs@pgroup.com
Note that PVF/pgdbg only supports MPI programs running all the processes on the same platform as PVF.
