ERROR: cudnn failure (CUDNN_STATUS_INTERNAL_ERROR) in mnistCUDNN.cpp:414
I don’t know why, please help me.
root@ubuntu22:~/test/mnistCUDNN# make clean && make
rm -rf *o
rm -rf mnistCUDNN
CUDA_VERSION is 11070
Linking agains cublasLt = true
CUDA VERSION: 11070
TARGET ARCH: x86_64
HOST_ARCH: x86_64
TARGET OS: linux
SMS: 35 50 53 60 61 62 70 72 75 80 86 87
/usr/local/cuda/bin/nvcc -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_80,code=sm_80 -gencode arch=compute_86,code=sm_86 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o fp16_dev.o -c fp16_dev.cu
nvcc warning : The 'compute_35', 'compute_37', 'sm_35', and 'sm_37' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
g++ -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include   -o fp16_emu.o -c fp16_emu.cpp
g++ -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include   -o mnistCUDNN.o -c mnistCUDNN.cpp
/usr/local/cuda/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_80,code=sm_80 -gencode arch=compute_86,code=sm_86 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o mnistCUDNN fp16_dev.o fp16_emu.o mnistCUDNN.o -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib64 -lcublasLt -LFreeImage/lib/linux/x86_64 -LFreeImage/lib/linux -lcudart -lcublas -lcudnn -lfreeimage -lstdc++ -lm
root@ubuntu22:~/test/mnistCUDNN# ./mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8906 , CUDNN_VERSION from cudnn.h : 8906 (8.9.6)
Host compiler version : GCC 11.4.0
There are 2 CUDA capable devices on your machine :
device 0 : sms 72  Capabilities 7.5, SmClock 1770.0 Mhz, MemSize (Mb) 48601, MemClock 7001.0 Mhz, Ecc=0, boardGroupID=0
device 1 : sms 72  Capabilities 7.5, SmClock 1770.0 Mhz, MemSize (Mb) 48601, MemClock 7001.0 Mhz, Ecc=0, boardGroupID=1
Using device 0
Testing single precision
Aborting...
I am also having the same issue.
cuda 11.8 and cudnn 8.6.0.163 on Nvidia Jetson Orin, arm64 Ubuntu 20.04
Hi @waglan ,
Do you face this on Jetson.
I face the same issue on Jetson AGX Orin with CUDA11.8 and cuDNN8.6.0.163, arm64 Ubuntu20.04
Did you fixed the issue?
cpu support avx ?
