I will install for the first time on my Forge Carrier Board for AGX Orin, which I use in projects. I made the necessary installations on the host computer and I start the flash process with the commands I shared in the image, but “FileNotFoundError: [Errno 2] No such file or directory: ‘images_list_signed.xml’ Reading board information failed.” i am getting the error. How can I solve it? Thanks in advance for your help.
When I start the flash process the terminal outputs are as follows:
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: cti-orin-agx-agx201-00, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0163 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0170 ] File rcm_state open failed
[ 0.0173 ] ERROR: failed to read rcm_state
[ 0.0173 ]
[ 0.0184 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0186 ] Assuming zero filled SBK key
[ 0.0177 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0226 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0300 ] Parsing partition layout
[ 0.0308 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0322 ] Kernel DTB used: None
[ 0.0322 ] WARNING: dce base dtb is not provided
[ 0.0322 ] Parsing partition layout
[ 0.0333 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0343 ] Creating list of images to be signed
[ 0.0351 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0358 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0367 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0370 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0411 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0414 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0457 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0460 ] adding BCH for mb2_t234_aligned.bin
[ 0.0483 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0594 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0597 ] adding BCH for mb2_t234_aligned.bin
[ 0.0730 ] Filling MB1 storage info
[ 0.0730 ] Parsing dev params for multi chains
[ 0.0784 ] Generating br-bct
[ 0.0793 ] Updating dev and MSS params in BR BCT
[ 0.0793 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0802 ] Updating bl info
[ 0.0811 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0818 ] WARNING: boot chain is not completed. set to 0
[ 0.0824 ] Generating signatures
[ 0.0835 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0838 ] Assuming zero filled SBK key
[ 0.0855 ] Warning: /home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/v3_cmac_6724.out is not found
[ 0.0867 ] Traceback (most recent call last):
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegrasign_v3.py", line 499, in tegrasign
retVal = sign_files_in_list(p_keylist, internal)
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegrasign_v3_internal.py", line 287, in sign_files_in_list
retVal = sign_files_internal(p_keylist, child, pkh, mont, sha_type, iv)
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegrasign_v3_internal.py", line 119, in sign_files_internal
write_file(hash_fh, buff_hash)
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegrasign_v3_util.py", line 679, in write_file
file_handle.write(data)
TypeError: a bytes-like object is required, not 'str'
[ 0.0867 ] Encounter exception when signing
[ 0.0867 ] a bytes-like object is required, not 'str'
[ 0.0868 ] ********* Error. Quitting. *********
File "./tegraflash.py", line 1383, in <module>
tegraflash_run_commands()
File "./tegraflash.py", line 1217, in tegraflash_run_commands
interpreter.onecmd(command)
File "/usr/lib/python3.6/cmd.py", line 217, in onecmd
return func(arg)
File "./tegraflash.py", line 855, in do_dump
self.chip_inst.tegraflash_dump(exports, args)
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py", line 2392, in tegraflash_dump
self.tegraflash_sign_images()
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py", line 566, in tegraflash_sign_images
dce_bin = self.get_file_name_from_images_list('dce_fw')
File "/home/pc_944/Masaüstü/ugur_forge_silme/ugur_forge/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py", line 3212, in get_file_name_from_images_list
with open(self.tegrahost_values['--signed_list'], 'r') as file:
FileNotFoundError: [Errno 2] No such file or directory: 'images_list_signed.xml'
