(Installing PyTorch for Jetson Platform)[Installing PyTorch for Jetson Platform - NVIDIA Docs]
sudo apt-get -y python3-pip libopenblas-dev; missing install
also, a note should be added about for (PyTorch for Jetson)[PyTorch for Jetson]
in the installation instructions for torchvision
python3 setup.py install --user there should be a comment the indicates that --user will cause the setup.py to fail if the install is being done in a virtual environment.
Error thrown: error: bad install directory or PYTHONPATH
to fix remove --user
