This is my version of Ubuntu:
PS C:\WINDOWS\system32> wsl --list --verbose
NAME STATE VERSION
* Ubuntu-22.04 Running 2
This is my gcc version:
zhao@ZhaoYH:~$ gcc --version
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
This is the result after entering nvidia-smi:
zhao@DESKTOP-CBA46OT:~$ nvidia-smi
Sat Sep 16 08:57:03 2023
| NVIDIA-SMI 530.50 Driver Version: 531.79 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 L... On | 00000000:01:00.0 Off | N/A |
| N/A 34C P8 1W / N/A| 10MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 23 G /Xwayland N/A |
When I followed Nvidia installation tutorial1 or Nvidia Tutorial 2 The same error below appears, an error occurred when I reached the second line of the command:
wget https://developer.download.nvidia.com/compute/cuda/12.2.2/local_installers/cuda_12.2.2_535.104.05_linux.run
sudo sh cuda_12.2.2_535.104.05_linux.run
zhao@DESKTOP-CBA46OT:~$ sudo sh cuda_12.2.2_535.104.05_linux.run
[sudo] password for zhao:
sh: 1: dkms: not found
Installation failed. See log at /var/log/cuda-installer.log for details.
zhao@DESKTOP-CBA46OT:~$ cat /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)
[INFO]: Initializing menu
[INFO]: Disabling driver option for WSL install
[INFO]: nvidia-fs.setKOVersion(2.17.5)
[INFO]: Setup complete
[INFO]: Installing: CUDA Demo Suite 12.2
[WARNING]: Unable to create .pc files, permission denied at /usr/lib/pkgconfig/!
[WARNING]: Cannot find manpages to install.
[INFO]: Installing: CUDA Documentation 12.2
[INFO]: Installing: Kernel Objects
[INFO]: cudaItem::install - kernelobjects
[INFO]: Able to write to /usr/local/kernelobjects/
[INFO]: Installing: nvidia-fs
[INFO]: dkms not found
[INFO]: DKMS is not installed,skip to static kernel module install
[INFO]: previous version of nvidia-fs is not installed, nvidia-fs version: 2.17.5 will be installed.
[INFO]: getting mofed Status
[INFO]: installation status shows that mofed is not installed,please install mofed before continuing nvidia_fs install.
[ERROR]: Install of nvidia-fs failed, quitting
My first installation was successful, but then the ~/.bashrc file was damaged. So I reinstalled Ubuntu. I tried various methods on the Internet to completely clear the remaining CUDA and Nvidia files, but I still got the same error. I even reinstalled Windows 11, but the error still did not disappear.
